Date/Time: Tue, 04 Nov 2025 16:32:24 +0000
CPU exception error when compiling
View Count: 1728
| [2021-06-16 16:31:56] |
| Sierra_Chart Engineering - Posts: 21306 |
Update to the latest prerelease and see if you still have the same issue. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-16 16:32:06
| [2021-06-16 17:34:07] |
| TriStar Trading - Posts: 184 |
Works fine here. Ver 2274. Danka Shoen!!
Date Time Of Last Edit: 2021-06-16 17:35:35
| [2021-06-17 06:25:45] |
| User4761 - Posts: 9 |
2274 working well, thankyou very much
| [2021-06-17 07:12:37] |
We still have not identified the exact problem other than we know it is related to calling the study function and setting this to true just before the DLL is unloaded: ACSIL Interface Members - Variables and Arrays: sc.LastCallToFunction We still need more time to look into it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
