Date/Time: Wed, 26 Feb 2025 18:04:38 +0000
Data not loading any more
View Count: 456
[2021-05-28 15:22:32]
mpva80 - Posts: 14
Hi Sierra Team,
In the middle of a trading session, the entire Sierra screen turned blank. All charts are of a sudden empty. Also my AMP account is suddenly not showing any more. See screenshots. When I try and load my saved charts, nothing happens.
Completely shut down my computer and restarted, but still same issues.
Kind regards,
Martijn
Private File
Private File
Private File
[2021-05-28 16:35:10]
Sierra_Chart Engineering - Posts: 18569
The main issue is you need to set Sierra Chart to use CQG. The Current Selected Service is not correct. Refer to:
CQG Trading Platform Service: Setup Instructions
Your Anti-Virus software is removing files that it should not be. There is definitely an issue with this, as we see the following in your Message Log:
SierraChartStudies_64.dll is missing. Possibly removed by anti-malware software.
You will need to make sure that the Sierra Chart files are not being removed by your anti-virus. Refer to the following:
Software Download: Antivirus/Anti-malware Software Flagging Sierra Chart Installer or other Files as Unsafe/Infected
Date Time Of Last Edit: 2021-05-28 16:35:33
