Date/Time: Sun, 27 Sep 2026 19:14:36 +0000
Trade statistics filetering?
View Count: 833
| [2021-05-25 19:33:55] |
| mattvk - Posts: 37 |
Is there a way to do basic filtering when looking at trade activity? E.g. show only long trades or short trades on the "period stats" tab?
Date Time Of Last Edit: 2021-05-25 19:44:46
| [2021-05-25 20:07:09] |
| John - SC Support - Posts: 48028 |
The only filtering that is available is what is at the top of the Trade Activity Log. Therefore, the only way to do the kind of thing you are asking about for the existing trades would be to modify the Fills to add a Note to them and then you can filter on the Note. Otherwise, you would want to enter a Text Tag for the trades. Refer to the following: Trade Activity Log: Note For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-05-26 03:00:40] |
Thanks, John. I think it would be a really useful feature to have a selector to filter long and short trades. Default: Long & Short Options: Long Only, Short Only I'm not sure if this is the appropriate place for feature requests, but this seems like it would be a relatively easy implementation with massive utility. |
| [2021-05-26 05:01:13] |
| User61576 - Posts: 458 |
+1
| [2021-05-26 13:59:36] |
We have tagged this as a Feature Request. This is an appropriate place to make a request. We just can not guarantee when we will be able to get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
