Date/Time: Tue, 04 Nov 2025 10:47:44 +0000
Request: TWConfig in Spreadsheets
View Count: 538
|   [2021-05-24 01:36:51]     |
| j4ytr4der_ - Posts: 947 |
                There doesn't appear to be any way to refer to the selected TWC in a spreadsheet.  I like using the Text Tag feature to concatenate together carious information about a trade so I can refer back to it later in my metrics.  What setup I was playing at the time would be nice to know, and using the TWC is the most sensible way to do that, it just doesn't have a row in the spreadsheet the way Trade Account does.  We're stuck either using a text tag that doesn't have the TWC, or use no text tag and get only the TWC. Could TWC be added to the Column I/J in the spreadsheet? I think this would be a very useful addition. Thanks for considering!  |
|   [2021-06-29 12:05:28]     |
                I'd just like to request this again as I again really wish I had this.  I keep forgetting which config I'm using and if I could display it on screen in a prominent place it would be a huge help.  Will you consider adding it to the spreadsheet (or adding a "TWConfig Display" study I suppose would work too) or is this something that will just never happen and I should abandon hope?
|   [2021-07-13 22:54:14]     |
                I realized today that I could modify the source for the Symbol Display study to get me the "TWConfig Display" study I asked for.  Quite easy to do really and very useful.
