Date/Time: Wed, 26 Feb 2025 14:21:12 +0000
TAB
View Count: 566
[2021-05-20 07:21:57]
User491428 - Posts: 87
Ich benutze Sierra schon eine Weile und finde es großartig. Was mir jedoch fehlt, sind Registerkarten, die ich jedem Diagramm hinzufügen kann. so etwas wie Ninja-Diagramm. Es wäre dann einfacher, schneller zwischen den verschiedenen Zeitparametern hin und her zu wechseln. so meine meinung. Vielleicht wird dies auch in der Software berücksichtigt?
[2021-05-20 13:48:28]
John - SC Support - Posts: 38172
From Google Translate:
I've been using Sierra for a while and I think it's great. What I'm missing, however, are tabs to add to any chart. something like ninja diagram. It would then be easier to switch back and forth between the various time parameters more quickly. so my opinion. Perhaps this is also taken into account in the software?
There are control bars that can be added to individual charts on which you can put the different time options you want to be able to switch between. Refer to the following:
Control Bar
[2021-05-20 14:46:15]
however, changing the time units takes a little longer. if in the 60 minute chart I load 300 days for a large overview and then switch to 5 minutes then the chart loads a minute. I do this several times a day. but if I have a tab where I also z. b. I have the s & p with 60 minutes and a tab s & p with 5 minutes, it's very quick. exactly the same with thret other instruments, everything is distributed on four monitors.
But now i have to change the chartbook every time and i have no overview of my four instruments.
I hope my english is not soo poor.....
[2021-05-20 16:26:44]
So you want to have open multiple charts and have a way to move between them? There are the Previous and Next Chart commands to do this, which also have keyboard shortcuts setup (F4 and F9 by default). Refer to the following:
Window, CB and CW Menus: Previous Chart (Window)
It sounds like you have your windows detached, in which case you could use the Windows Task Bar to quickly choose a particular chart. Or, if they are not detached, then there are the Chart Tabs to select the chart.
If you are looking for some other tool, such as a small chart selector, or something like that, we do not have that available. It would be something that would need to be developed and it is not something we can put time into right now.
