Date/Time: Wed, 26 Feb 2025 10:01:30 +0000
ATR Levels
View Count: 1823
[2021-05-16 09:58:20] |
User455956 - Posts: 6 |
Hello again. I would like to have a ATR levels high low as shown in the screenshot I followed this post Average True Range Indicator but nothing happen I m not sure Im doing it correclty 1 - Created Daily OHLC + ATR + Spreasheed formula (+ATR) and (-ATR) on my daily chart 2 - Added Study/Price Overlay with my ATR on intraday chart It draw a line on the bottom of my intraday chart but it flattens it. Do you have any solution ? Thank you Date Time Of Last Edit: 2021-05-16 10:02:41
[2021-05-17 16:19:38] |
John - SC Support - Posts: 38172 |
All we can tell you is that you have something wrong in there somewhere. The study you are overlaying has values that are close to zero, which is why your chart is flattening out, as it is trying to draw both of the data sets in the same region. You will have to go through what you did and find where the mistake is. We can not say where it is, as there are too many places to look. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-17 16:51:23] |
User907968 - Posts: 833 |
1 - Created Daily OHLC + ATR + Spreasheed formula (+ATR) and (-ATR) on my daily chart 2 - Added Study/Price Overlay with my ATR on intraday chart You need to overlay each of the spreadsheet formula studies, not the ATR. |
