Date/Time: Tue, 25 Feb 2025 23:04:30 +0000
The Ghost in SC or my machine :)
View Count: 552
[2021-05-03 13:23:48]
User968625 - Posts: 260
Hello SC,
This strange.I am sure there is a logical explanation but the clock study and symbol display studies are not on the chart studies, again, NOT studies that are now on the chart BUT I have multiple charts that display them. They might have been on one of the charts that I duplicated but I am sure I have removed them. they still display on some charts. now, not sure what to do about this ghost. see the image and how the time display is different than the one on the title. Can you help
imageTime display.png / V - Attached On 2021-05-03 13:23:25 UTC - Size: 24.21 KB - 213 views
[2021-05-03 15:53:06]
John - SC Support - Posts: 38172
The display of those items actually uses the Tool drawing methods to display the information on the screen. Sometimes, the system can get confused and the drawing tool gets separated from the study, so it will still exist as a drawing tool.
First, make sure that the study itself is no longer on the chart by going to Analysis >> Studies and ensuring that the particular study is not on the chart. If it is, remove it and see if that also removes the drawing on the screen.
If the drawing is still there, then right-click on it and select Erase Drawing. If it will not remove, then the study is still on the chart and you need to remove it first.
[2021-05-03 18:43:15]
Thanks, John, I have to erase them manually from each chart (they are not studies). It worked, thanks
