Date/Time: Tue, 25 Feb 2025 20:05:45 +0000
Order
View Count: 497
[2021-04-28 19:08:55] |
markoosterling0348 - Posts: 1 |
Hi guys, I was long on MES at 4175 when my internet connection blew up. I had my stop at 4177. Just restarted, price moved to 4200 and my order is gone. How comes???? |
[2021-04-28 19:35:28] |
John - SC Support - Posts: 38165 |
First, ensure that your order is truly closed by checking with your broker. Next, look at your Trade Activity Log to determine what happened. Most likely you were using Server-Side managed orders, in which case, based on what you state, your position should have closed when the price hit 4177, as you state that you had a stop at that level. Refer to the following for general information on how to start the process of analyzing the Trade Activity Log: Trade Activity Log: Basic Analysis Procedure for Trading Question/Issue For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
