Date/Time: Tue, 25 Feb 2025 19:47:35 +0000
Chart Scaling Issue
View Count: 491
[2021-04-26 15:21:56]
SvenSon - Posts: 17
Dear Sierra Chart Team.
My charts are all linked to a Quoteboard and two of these Charts have specific scale settings. I put them to Re-center when last bar exceeds a certain number of ticks from the center. (screenshot)
When I change between symbols on my Quoteboard these two charts always look like they are emerged or squeezed together. I also took a screenshot. Do you know how I can solve this problem, because it is kind of inconvenient to reset the priceladder so the chart looks normal.
Thanks in advance. :)
image1.PNG / V - Attached On 2021-04-26 15:20:14 UTC - Size: 52.58 KB - 188 views
image2.PNG / V - Attached On 2021-04-26 15:20:24 UTC - Size: 73.61 KB - 199 views
image3.PNG / V - Attached On 2021-04-26 15:20:31 UTC - Size: 179.12 KB - 204 views
[2021-04-26 16:26:52]
John - SC Support - Posts: 38165
The only solution for what you are doing is to set the scaling to be Automatic. Refer to the following:
Chart Scale and Scale Adjusting: Automatic (Scale Range)
The problem you are seeing is that you have the scale set to a "Constant Range", so when you change the symbol, that range is no longer valid to cover the range for the new symbol.
[2021-04-26 16:55:01]
SvenSon - Posts: 17
Too bad. I was hoping there is some kind of setting which I just haven't found in the Software.
But yeah it makes sense now with the range.
Thank you John.
Have a great day.
