Date/Time: Tue, 25 Feb 2025 17:27:52 +0000
arrow acknowlwdgement on chart do not corespond to actgula oders,.e. open oede shows close
View Count: 816
[2021-04-21 14:01:07]
User427561 - Posts: 217
arrow acknowlwdgement on chart do not corespond to actula oders,.e. open order shows close and vice versa. ho do i straightnen out this situation ?closing arrowss on chart do not show profit/loss of trade ? can you lead me me to the linkof the page where the arrows can be rearranged ? TX
Date Time Of Last Edit: 2021-04-21 14:09:35
[2021-04-21 14:28:44]
John - SC Support - Posts: 38163
You are either missing an order fill, or the Order Fills Start Date/Time is incorrect. Refer to the following:
Trade Activity Log: Solving Inaccurate Trade Statistics for Charts Field Values
[2021-04-21 17:24:17]
thanks but stil unable resolve the issue, is john at support availabe to help me out on this? im available anytime daytime est he is available to call at 904 272 3407
[2021-04-21 17:53:11]
The simplest solution to your problem is to find a time when you were flat in your trades and then set the following to that date and time:
Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu)
This will at least take care of your fills going forward.
But, to determine the root of the problem, you need to go back through your order fills and find where one is missing. Then you can add an order fill to fix the issue.
In general, you will find all the information you need on this page:
Trade Activity Log
We simply do not have time to go through this for you, as we do not do anything different from what we have specified above.
[2021-04-22 13:42:20]
Thanks Jon=hn, The procedure going forward SEEMS TO WORK(GOING fOREWard on sim).
but will that work on live trading as well? or would I have to do the same procedure while on live?e. Hate to be experimenting on live.
[2021-04-22 13:52:10]
It will work for Live as well.
[2021-04-22 15:25:45]
charts arrows reverted back to wrong behaviour. open arrow shows closed and vice versa. Would appreciate you taking a look at it. thanks
ps not really interested at finding out origin of problem as long as future performance works well. will be careful at watching log however to avoid future malperformance if it ever reoccurs.
Date Time Of Last Edit: 2021-04-22 15:34:08
[2021-04-22 15:44:49]
If you do not hold positions overnight, then another option is to set the setting for Load Order Fills For Current Day Only. Then you will only see the orders for today on your chart. Again, this just helps remove any missing fills from the past causing an offset in the current orders.
Otherwise, you have to go through your orders and find where the offset first started and then determine the missing order fill and add it in. Refer to the following:
Trade Activity Log: Manually Inserting Missing Order Fills
[2021-04-22 17:57:41]
I am just unable to set my system right. Can you please arrange a remote assistance to help pleasea? my phone is 904 2723407 All i need is to set migy futre orders OK not interrested in prior errors
[2021-04-23 15:26:27]
updating to vr 2250 seems to have resolved my problem.
Date Time Of Last Edit: 2021-04-23 15:45:48
[2021-04-23 16:53:41]
does that imply it was a software problem ?
[2021-04-23 19:50:43]
Do you know what version of software you were on previously? If it was a big jump, then it's possible there was a change that could have impacted you, but in general, there has not been any changes to the way the order fills are connected in a long time.
But, we are glad things are back working for you.
