Date/Time: Tue, 04 Nov 2025 11:13:54 +0000
[Programming Help] - sc.Highest needs 4 arguments to work in manual loop but compiler says expects 3
View Count: 811
[2021-04-21 09:42:48]
User785302 - Posts: 8
Hello
The following code does not compile.
Error:
- Starting remote build of Custom Studies Source files: ScratchPad.cpp. 64-bit -- 04:36:10
Allow time for the server to compile the files and build the DLL.
The remote build did not succeed. Result:
ScratchPad.cpp: In function 'void scsf_GetHighest(SCStudyInterfaceRef)':
ScratchPad.cpp:32:60: error: no matching function for call to 's_sc::Highest(c_ArrayWrapper<float>&, float&, int&, int)'
32 | sc.Highest(Sg_BB.Arrays[0], Sg_Highest[Index], Index, 10);
In file included from ScratchPad.cpp:6:
sierrachart.h:787:18: note: candidate: 'c_ArrayWrapper<float>& s_sc::Highest(SCFloatArrayRef, SCFloatArrayRef, int, int)'
787 | SCFloatArrayRef Highest(SCFloatArrayRef In, SCFloatArrayRef Out, int Index, int Length)
sierrachart.h:787:62: note: no known conversion for argument 2 from 'float' to 'SCFloatArrayRef' {aka 'c_ArrayWrapper<float>&'}
sierrachart.h:792:18: note: candidate: 'c_ArrayWrapper<float>& s_sc::Highest(SCFloatArrayRef, SCFloatArrayRef, int)'
792 | SCFloatArrayRef Highest(SCFloatArrayRef In, SCFloatArrayRef Out, int Length)
sierrachart.h:792:18: note: candidate expects 3 arguments, 4 provided
-- End of Build -- 04:36:13
Here is my SCSF code:
SCSFExport scsf_GetHighest(SCStudyInterfaceRef sc) {
  SCSubgraphRef Sg_BB = sc.Subgraph[0];
  SCSubgraphRef Sg_Highest = sc.Subgraph[1];
  if (sc.SetDefaults) {
    sc.GraphName = "Testing Highest";
    sc.GraphRegion = 0;
    Sg_BB.Name = "BB";
    Sg_Highest.Name = "Highest";
    return;
  for (int Index = sc.UpdateStartIndex; Index < sc.ArraySize; ++Index)
    sc.BollingerBands(sc.BaseData[SC_LAST], Sg_BB, Index, 10, 2, MOVAVGTYPE_SIMPLE);
Regards
[2021-04-21 16:41:28]
You need to correct this line as follows:
sc.Highest(Sg_BB.Arrays[0], Sg_Highest, Index, 10);
The result will go into Sg_Highest at the element at Index.
