Date/Time: Tue, 25 Feb 2025 16:09:24 +0000
Morning crashes - version 2247
View Count: 573
[2021-04-19 16:38:51]
User337568 - Posts: 60
Hi:
SC just disappeared twice this morning and I lost my alert settings and control bar.
I sent my message log however, I did not include an explanation
Requests:
1. How do I get my alerts and control bar back?
2. How do I deal with the odd shutdowns?
[2021-04-19 17:49:42]
John - SC Support - Posts: 38158
Unfortunately, there is nothing in the Message Log that gives us any information. This is not unusual, as a system crash is an unexpected event, so there typically is nothing to log.
But, what we want you to do is to start Sierra Chart in Safe Mode which will stop any non-Sierra Chart studies from being loaded and used. See if you have any issues in Safe Mode for awhile, and if you do not have issues, then the problem is probably in one of the custom studies you have. Refer to the following:
Sierra Chart - Software Login Instructions: Using Safe Mode
With regards to the Control Bars and Alerts, we need more information. Are you stating that the customized settings that you have for these are gone?
If that is the case, then you will want to get one of the backup files for your Sierra4.config file and replace that file in your main Sierra Chart folder with the backup. Refer to the following:
Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File: Restoring Backup Global Configuration File
If it is something else, then let us know exactly what is happening.
We did notice the following in your Message Log:
Circular chart reference detected. Charts: 3, 1. Chartbook: 2021-04-15 15 S DOM Test.Cht. | 2021-04-19 14:26:48.546
You should fix this issue as it can cause major slowdowns to your system. Refer to the following:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.9 References to Other Charts / Continuous Full Recalculation of Charts
[2021-04-19 18:30:02]
I did the delete/copy of my Sierra4.config, and that worked.
Thank you for the safe mode idea.
[2021-04-20 16:23:38]
We are suspecting this is an operating system level issue. Make sure to run all of your operating system updates.
Date Time Of Last Edit: 2021-04-20 16:24:19
[2021-04-20 16:32:29]
Thank you... I have taken all the updates and I agree.
