Date/Time: Tue, 04 Nov 2025 14:59:25 +0000
FDXS Availability
View Count: 621
|   [2021-04-19 12:27:33]     |
| User183843 - Posts: 12 |
                Hi SC team! Do you have an indication, when FDXS will be available via Denali/Eurex? btw, keep up the great work! thanks, Sascha  |
|   [2021-04-19 14:28:27]     |
                It has already been added but we have not yet listed it for other services other than SC Data-All Services. We will be doing that today. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-06-29 14:22:15]     |
| Pawel_Szpak - Posts: 48 |
                Hi, Any update on this? I cannot see FDXS in my symbol list. I have FDAX and FDXM, but not FDXS. Manually changing FDAXU21_FUT_Eurex to FDXSU21_FUT_Eurex doesn't work. I've tried Symbol Settings -> Update from Server and no change For what it's worth, I'm using Denali Feed, but am only paying for the CME bunch a the moment, but wanted to see how this new contract was trading vs FDXM and FDAX, so it's not a problem if it's delays at this stage.  |
|   [2021-06-30 18:58:14]     |
| Sierra_Chart Engineering - Posts: 21301 |
                This symbol has been added for the Sierra Chart order routing service. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing  |
