Date/Time: Tue, 25 Feb 2025 14:13:59 +0000
Historical Data
View Count: 482
[2021-04-14 16:12:45]
User417940 - Posts: 3
Dear Sirs,
since 3 days I cannot download the historical datas for F.US.ENQM21. What a kind of package version do I need to get the historical chart data.
Thank you.
[2021-04-14 17:01:57]
John - SC Support - Posts: 38150
You should not have any issue getting the historical data for any symbol traded on the CME Group, as you are setup to get your data from our Denali Exchange Data Feed.
The main thing we can think that may be happening is that you are expecting data further back than the beginning of the contract period, but you are not using a Continuous Futures Contract. Refer to the following:
Continuous Futures Contract Charts
If it is not the continuous contract, then what exactly is the issue? Are you getting an error message, and if so what does it state? Are you just not able to get data back beyond a certain time?
[2021-04-16 14:45:16]
Sierra_Chart Engineering - Posts: 18555
Also follow the instructions here:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services (Integration with Trading Services)
