Date/Time: Tue, 25 Feb 2025 11:37:37 +0000
Cannot load chartbook
View Count: 522
[2021-04-13 15:11:00] |
User924806 - Posts: 20 |
Hi, I am trying to load the Chartbook for ES Mini but everytime when is trying to load it freezes, so I have to reboot the entire computer. It works ok when I'm opening other Chartbooks, like the CL and GC...It is the first time it's happening so what do I need to do?
[2021-04-13 16:33:14] |
John - SC Support - Posts: 38150 |
Can you start a new chart for that symbol by selecting File >> Find Symbol? If you can open a new chart, then you can try to open the existing chartbook by starting Sierra Chart in Safe Mode. This will tell you if the problem is related to a 3rd party study. Refer to the following: Sierra Chart - Software Login Instructions: Using Safe Mode If it is a 3rd party study, then you will have to recreate your chart and let the developer of the study know that you are having an issue with their study. Otherwise, let us know what the results from the above are and what happens. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-13 18:31:26] |
Also refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.16 - What to do if Sierra Chart is in a frozen state for an extended time due to extended high CPU usage caused by an automatically or manually opened Chartbook If you are having to restart your computer, this sounds like a system level issue. We recommend installing Sierra Chart on its own dedicated solid-state drive: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.29 - Solid State Drives / SSD Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-13 18:31:46
