Date/Time: Tue, 25 Feb 2025 11:29:52 +0000
Affiliat/Connecting
View Count: 685
[2021-04-12 16:53:46] |
galszabocs0 - Posts: 1 |
Dear Sierra Chart group ! I have got this problem, i can not connecting to SC, I have got account at AMP FUTURES(https://www.ampfutures.com/) Affiliate ID: default "Connecting error message from service: SC Futures Order Routing/Data | Connection error: Trade account not assigned. | Date-Time 2021-04-10 11:33:11" Thanks Best Regards, |
[2021-04-12 19:14:12] |
John - SC Support - Posts: 38150 |
Your service is still set to SC/TT Futures Order Routing. AMP stopped support for the Sierra Chart Order Routing Service about 2 months ago and they should have informed you of this. Additionally, they should have moved you to CQG for your order routing going forward. If you have not received your CQG credentials, then you need to talk to AMP about this. Once you have your CQG credentials, then follow these instructions to connect your Sierra Chart software to CQG: CQG Trading Platform Service: Setup Instructions After the above is complete, then open your Chartbooks (if not already open) and select Edit >> Translate Symbols to Current Service. This will change your symbols to CQG symbols. Then you will be all set to trade again. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
