Date/Time: Tue, 25 Feb 2025 08:33:14 +0000
No answer
View Count: 654
[2021-04-07 10:13:07]
User657856 - Posts: 61
Yesterday I sent you a question via the Support Board and I have not received any answer.
Earlier, I sent you a question from an e-mail and got the answer that I should write a question through the Support Board.
The effect is that I still can't play in the live market.
How long I have to wait?
Bogdan
Thanks.
Date Time Of Last Edit: 2021-04-07 13:34:23
[2021-04-07 13:34:16]
We do not see any recent question from you on this Support Board. What is the question?
Also provide us the message log information requested below.
Reconnect to the data feed:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2021-04-07 19:38:04]
I can't play live
I gave Live Mode and there is only a demo.
I gave Simulated Live and it's only a demo.
i want to play in a live market.
Bogdan
Date Time Of Last Edit: 2021-04-08 14:09:47
[2021-04-07 20:31:27]
John - SC Support - Posts: 38150
When you go to "Live Mode" are you changing the Connection Type on the Data/Trade Service Settings window?
If that is set to Live, then are you taking the Sierra Chart system out of Simulation Mode by ensuring that there is not a checkmark next to the option Trade >> Trade Simulation Mode On?
Refer to the following regarding Simulation Mode:
Trade Menu: Trade Simulation Mode On (Trade menu)
[2021-04-08 04:55:30]
Also update Sierra Chart:
This resolves an issue when changing the Connection Type, it does not going to an effect on a reconnection due to the method of connection to Transact. But we have a workaround implemented.
Date Time Of Last Edit: 2021-04-08 14:09:13
[2021-04-08 13:48:08]
Hello.
I did as you wrote.
I removed the check mark next to Trade Simulation Mode On.
Thank you so much for help.
Effect I'll see how I play
Bogdan
Date Time Of Last Edit: 2021-04-08 14:09:34
