Date/Time: Sun, 24 Nov 2024 02:32:17 +0000
Data provider
View Count: 2539
[2013-04-21 12:16:41] |
Happy trader - Posts: 6 |
Hi What data provider do i use to see UK LSE stocks as well as Stock and commodity futures? |
[2013-04-21 19:50:39] |
Do you need historical data only?
[2013-04-21 20:18:18] |
Only a year or so. But needed for daily analysis for daily and 4 hour time frames |
[2013-04-23 02:29:09] |
Use the Sierra Chart Historical Data Service: http://www.sierrachart.com/index.php?l=SierraChartHistoricalData.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-23 07:10:33] |
Hi Does end of day mean you see the daily bar after midnight, or when the market closes? Thus 4:30pm GMT for LSE and 4:30 for NEw York stock exchange? And do you also get commodity futures? |
[2013-04-23 07:14:45] |
In the case of the LSE, we are not certain of the delay. Most of the other exchanges are delayed less than 30 minutes. Commodity futures are included. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-23 09:11:29] |
Trint - Posts: 115 |
Is there likely to be, or is there any intention to add Historic Intraday data for the LSE ..? It would be very handy to have.
[2013-04-23 15:54:11] |
Yes. This will be supported through E-Signal and also Teletrader: http://technologies.teletrader.com/Financial-Services/TeleTrader-Data-Universe-%281%29/Cash-Markets---Indices.aspx Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-24 08:46:53] |
If anyone's interested, spoke to both e-Signal and Teletrader. The spokeswoman(uk - Interactive Data) for e-signal just mentioned the On-Demand service and wasn't aware of Sierra being a third party to their services (thought they may have talked about the new upcoming feed partnership with Sierra if different from on-demand). Bit of a delayed response from Teletrader but on the whole I think I'll have to see what they have to offer, maybe a trial.
[2013-04-24 08:53:40] |
Neither E-Signal or Tele-trader is currently supported by Sierra Chart. They are both under development.
[2013-09-07 15:59:04] |
taipeicity - Posts: 52 |
sir, I love your sierrachart, i have been using this stupid Qcharts for more than10 years, expensive and data always delayed at opening of the market, basically it is useless for trading, I want to quit Qcharts within 2 weeks, before quitting it, I am trying to export intraday Qchart data to comma delimited *.csv file right now I try to load this QCHART csv file to sierrachart, but no data loaded , what did I do wrong? |
[2013-09-07 20:45:40] |
User201106 - Posts: 62 |
Why bother with trying to export Qchart data? Just choose a good data feed for Sierra like IQFeed or Barchart. If you only need Futures data then a good broker feed may suffice.
Date Time Of Last Edit: 2013-09-07 20:46:22
[2013-09-09 17:42:31] |
Show us the first 100 lines of your CSV file. Post it here.
[2013-09-11 07:59:51] |
dear sir this is the data csv file i have downloaded from qcharts i opened it on excel. |
2013-09-06_qchart.jpg / V - Attached On 2013-09-11 07:59:39 UTC - Size: 354.62 KB - 526 views |
[2013-09-11 08:03:54] |
another problem as following (nothing to do with the above qchart problem) my ES chart missing ES-201309-globex chart, 9/5 thursday, 9/6 friday and sunday data feed missing... |
missing_data.jpg / V - Attached On 2013-09-11 08:03:44 UTC - Size: 119.12 KB - 561 views |
[2013-09-11 08:57:59] |
The CSV text file in the image you have given, does look correct. Follow the instructions here to import it: http://www.sierrachart.com/index.php?l=doc/doc_ImportExport.html#import After importing you may need to adjust the times to GMT. This is explained in the steps. We see you are using Interactive Brokers. Therefore you most likely encountered a pacing violation. Refer to help topic 37 about this here: http://www.sierrachart.com/index.php?l=doc/helpdetails37.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
