Date/Time: Tue, 25 Feb 2025 05:11:16 +0000
Logon unsuccessful. Server message: Your logon is disabled. Contact your FCM. | 2021-04-05
View Count: 1891
[2021-04-05 13:57:31]
User565325 - Posts: 11
Hi, i have this message when i log and try to connect to data:
Software version: 2219 64-bit | 2021-04-05 08:50:06.112
Primary Thread ID: 7728 | 2021-04-05 08:50:06.112
Usage end date: 2021-05-06 | 2021-04-05 08:50:06.112
Enabled for: Advanced Features 2. | 2021-04-05 08:50:06.112
Enabled for: Sierra Chart Historical Data Service. | 2021-04-05 08:50:06.112
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-04-05 08:50:06.112
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2021-04-05 08:50:06.112
Enabled for exchange2: CME | 2021-04-05 08:50:06.112
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-04-05 08:50:06.112
Current selected Data/Trading service: CQG WebAPI | 2021-04-05 08:50:06.112
Custom symbol settings values: enabled | 2021-04-05 08:50:06.112
Chart Update Interval: 10 | 2021-04-05 08:50:06.112
Intraday Data Storage Time Unit: 0 | 2021-04-05 08:50:06.112
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-04-05 08:50:06.112
2021-04-05 13:50:06 Local computer time in UTC | 2021-04-05 08:50:06.112
2021-04-05 08:50:06 Local computer time in SC Time Zone | 2021-04-05 08:50:06.112
2021-04-05 13:48:31 Server time in UTC | 2021-04-05 08:50:06.112
Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-04-05 08:50:06.112
Program path: C:\SierraChart\ | 2021-04-05 08:50:06.112
Data Files path: C:\SierraChart\Data\ | 2021-04-05 08:50:06.112
OS Version Number: 10.0 | 2021-04-05 08:50:06.112
Locale Setting: C | 2021-04-05 08:50:06.112
DLLs: UserContributedStudies_64.dll | 2021-04-05 08:50:06.112
Allowed protected custom studies: | 2021-04-05 08:50:06.112
CQG WebAPI | Connecting to server api.cqg.com | 2021-04-05 08:50:21.502
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-04-05 08:50:21.502
CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. | 2021-04-05 08:50:21.502
CQG WebSocket socket (2) | New receive buffer size: 5242880 | 2021-04-05 08:50:21.502
CQG WebSocket socket (2) | Connecting to IP: 195.166.124.165. | 2021-04-05 08:50:21.502
CQG WebSocket | Opening WebSocket. | 2021-04-05 08:50:21.532
CQG WebSocket | Sending WebSocket handshake. | 2021-04-05 08:50:21.532
CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-04-05 08:50:21.637
CQG WebSocket | Server header | Connection: upgrade | 2021-04-05 08:50:21.637
CQG WebSocket | Server header | Sec-WebSocket-Accept: P+RpP6ejdx5WfQz6ILLR1ILdeUo= | 2021-04-05 08:50:21.637
CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2021-04-05 08:50:21.637
CQG WebSocket | Server header | Upgrade: websocket | 2021-04-05 08:50:21.637
CQG WebSocket | Server header | | 2021-04-05 08:50:21.637
CQG WebSocket | Web socket state is now open. | 2021-04-05 08:50:21.637
CQG WebAPI | WebSocket connected. | 2021-04-05 08:50:21.637
CQG WebAPI | Sending market data logon message. | 2021-04-05 08:50:21.637
CQG WebAPI | Logon unsuccessful. Server message: Your logon is disabled. Contact your FCM. | 2021-04-05 08:50:22.110
CQG WebSocket socket (2) | CloseSocket call. | 2021-04-05 08:50:22.143
CQG WebSocket socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2021-04-05 08:50:22.143
CQG WebAPI | Disconnected. | 2021-04-05 08:50:22.143
CQG WebAPI | Not reconnecting due to connection error condition. | 2021-04-05 08:50:22.144
CQG WebSocket | WebSocket closed. | 2021-04-05 08:50:22.144
CQG WebAPI | WebSocket closed. | 2021-04-05 08:50:22.144
CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-04-05 08:50:22.144
CQG WebSocket socket (2) | Write has completed. Shutdown being performed. | 2021-04-05 08:50:22.172
CQG WebSocket socket (2) | Shutdown started. Waiting for graceful close. | 2021-04-05 08:50:22.172
Where is the problem?
Thank you
Patrice
[2021-04-05 14:00:49]
I have paid everything to access to CME data 10.4$
But it won't connect.
Do you have change something to access to CME with CQG?
Best regards
Patrice
[2021-04-05 15:41:18]
You need to contact your broker about this particular error.
