Date/Time: Tue, 25 Feb 2025 08:40:55 +0000
[User Discussion] - Connecting Serra Charts to Rithmic data and Trade ordering
View Count: 916
[2021-03-31 15:23:58]
User281554 - Posts: 8
Can someone please help me on how to connect Sierra Charts to Rithmic 01. Broker is Ironbeam/ Discount Trading. I downloaded a DTC Bridge patch that Discount sent me but when executed says "Port number not specified will exit".
I was told I need to use a Sierra Chart Version Pre 12/31/2020. I'm currently using version 2239. Don't know if that's the problem. Please help, Thank You
[2021-04-07 18:26:53]
user_xyz - Posts: 446
Not sure if you figured this out but if you run the DTC Bridge program directly you will get "Port number not specified will exit" error. If your Data/Trade Service is set to -> Rithmic Trading and you connect SC will auto launch the DTC Bridge and connect you.
[2021-04-07 18:30:34]
Did That and it did not work.
[2021-04-07 18:38:22]
What is the log file in the Rim folder telling you?
[2021-04-07 18:48:28]
The Error message? Log file? Please direct me.
[2021-04-07 18:59:38]
Example c:\sierra\rim\rithmic.log open that with a text editor and you should see an error
[2021-04-07 19:10:11]
There is no file by that name with that extension. (rithmic.log)
[2021-04-07 19:25:36]
Download the files from here Rithmic Bridge Files and try again... those are the files I used and everything worked fine. So remove all the files you have in your Rim folder and replace with these then try again.
Date Time Of Last Edit: 2021-04-07 19:26:09
[2021-04-07 19:39:56]
Still not there. I download. Unzip it. This is what I get:
DTCBridge Application 2593KB
rim_ssl_cert_auth_params File 2KB
rim_ssl_client_prams File 2KB
rim_ssl_client_private_key File 2KB
That's it.
[2021-04-07 19:57:02]
You have your Data/Trade Service set to -> Rithmic Trading setup, pointing to the right server? There are 2 Rithmic servers in the drop-down don't use the one that says DTC.
Attach a screenshot of your error message
[2021-04-07 20:16:56]
Well, sorry, but I can't do that at the moment because I actually defunded and suspended the account we are referring to. It was taking too long to get support and I felt that if this was going to be the case going forward, even occasionally, and considerable money would be at risk on occasion when I had a technical problem, that would be untenable. However, I did not close the account altogether in case the problem did eventually get resolved as we are trying to do here. So what I can tell you if it helps is that I set the Data/ Trade Service to "Rithmic 01". At that time it did not work.
[2021-04-07 20:31:29]
Haha wish you would have told me that first, I wouldn't have wasted my time. ;-) This thread is marked as User Discussion and I believe SC doesn't monitor or give support to these so...
Cheers
