Date/Time: Tue, 06 Oct 2026 01:57:07 +0000
Problems with Receiving Data for Forex Symbols
View Count: 1353
[2021-03-27 13:09:58]
Botan626 - Posts: 294
SC v2239, this was first mentioned around 4 p.m. UTC on Thursday.
Data receiving speed was extremely slow, took more than 30 mins to download data for around 30 forex FXCM symbols after less than 1 day of non-usage time, and data itself was corrupt.
Yesterday it took more than 5 minutes for SC to update data for symbols which get quotes every 15 minutes, like EURZAR.
This happened just now: I changed From date for AUDUSD to 2020-03-01, this is how SC downloaded data for it: http://www.sierrachart.com/image.php?Image=161685045849.png
Date Time Of Last Edit: 2021-03-27 13:11:42
[2021-03-27 13:18:23]
I changed From date to 2020-02-01 for AUDUSD, now SC is downloading data correctly.
This is the second time I see SC downloads data properly from the second try, yesterday was the same case for another symbol.
[2021-03-27 13:43:17]
SC had no problems with downloading data after I deleted all scid files in the Data folder on Friday morning.
My guess is v2239 has some issues with re-writing/updating data files on the disk.
Tried just now:
Data for AUDJPY was downloaded from 2021-01-25 up to date, I changed From date to 2021-01-01.
SC was like this for several minutes: https://i.imgur.com/5CagSY3.png
And after it finished downloading data: https://i.imgur.com/mr5LWg2.png
[2021-03-27 14:56:54]
Now it doesn't download data even from 4-th and 5-th try:
https://i.imgur.com/cQA2s8V.png
https://i.imgur.com/DOkwf6T.png
[2021-03-29 04:01:50]
Sounds like you have some connectivity issue with the downloading of historical data. Refer to:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Error when Downloading Historical Intraday Data from the Sierra Chart Historical Data Server
Date Time Of Last Edit: 2021-03-29 04:01:57
[2021-03-29 06:16:24]
This setting is in different place now: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Using Port 80
Date Time Of Last Edit: 2021-03-29 06:19:16
[2021-03-29 06:24:02]
This topic says: Sierra Chart needs to be provided access to ports 10149, 10150 to connect to the historical data server.
How can I check manually, that SC has access to ports 10149, 10150?
I have only Windows Defender Firewall running, I don't use a router.
[2021-03-29 06:29:40]
I set 'Use Port 80 For Historical Data' to true. The downloading speed is still terrible, close to 0.
[2021-03-29 06:51:41]
I set 'Use Port 80 For Historical Data' back to false. This is how SC was downloading data for CADJPY:
Triggering next historical data download in queue. | 2021-03-29 09:44:23.951
HD Request # 4 | Downloading Intraday chart data for CADJPY to the file CADJPY.scid. Service: fxcm | 2021-03-29 09:44:23.951
HD Request # 4 | Download start date-time: 2021-03-29 08:55:23.000000. File last date-time: 2021-03-29 08:55:23.389000 | 2021-03-29 09:44:23.951
HD Request # 4 | Using server: ds4.sierracharts.com port 10149 | 2021-03-29 09:44:23.951
Socket (2) | Creating socket. | 2021-03-29 09:44:23.952
Socket (2) | New receive buffer size: 5242880 | 2021-03-29 09:44:23.952
Socket (2) | Connecting to IP: 192.81.56.146. | 2021-03-29 09:44:23.952
Chart #3 has tagged chart #2 for full recalculation. Chartbook: 01.Cht | 2021-03-29 09:44:24.123
Socket (4) | Socket gracefully closed by remote side. | 2021-03-29 09:44:24.145
Socket (4) | Closed. | 2021-03-29 09:44:24.146
HD Request # 4 | Setting DTC encoding to Binary VLS | 2021-03-29 09:44:24.364
HD Request # 4 | Sending historical data logon request message. | 2021-03-29 09:44:24.364
HD Request # 4 | Requesting Intraday data. Start date-time: 2021-03-29 08:55:23. Record interval: 0. Symbol: CADJPY | 2021-03-29 09:44:24.564
CHFJPY[M] 0.120 Range #2 | Performing a full recalculation because it has been tagged. Chartbook: 01.Cht | 2021-03-29 09:44:24.605
HD Request # 4 | Decompressing data. | 2021-03-29 09:44:24.765
HD Request # 4 | Receiving Intraday data for CADJPY starting at 2021-03-29 08:55:23.389000 | 2021-03-29 09:44:25.293
Opened cached Intraday file: C:\SierraChart\Data\CHFJPY.scid. Thread ID: 10524 | 2021-03-29 09:44:26.772
Socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-03-29 09:45:08.113
Socket (2) | Socket gracefully closed by remote side. | 2021-03-29 09:45:08.113
Socket (2) | CloseSocket call. | 2021-03-29 09:45:08.113
Socket (0) | CloseSocket call. | 2021-03-29 09:45:08.113
Socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-03-29 09:45:08.113
Socket (2) | Closed. | 2021-03-29 09:45:08.113
HD Request # 4 | Error downloading historical Intraday data for CADJPY. The network socket has been closed. Retrying download. | 2021-03-29 09:45:08.116
Added historical Intraday data request for CADJPY to the queue. | 2021-03-29 09:45:08.116
Triggering next historical data download in queue. | 2021-03-29 09:45:08.116
Historical data download thread signaled to stop. | 2021-03-29 09:45:08.116
HD Request # 4 | Timestamp of first Intraday data file record written: 2021-03-29 08:55:40.307000 | 2021-03-29 09:45:08.116
HD Request # 4 | Received 132 records from 2021-03-29 08:55:23.389000 to 2021-03-29 08:58:16.254000 (2.9 minutes) and wrote 131 records for CADJPY | 2021-03-29 09:45:08.117
HD Request # 4 | Completion time: 45s | 2021-03-29 09:45:08.121
HD Request # 5 | Downloading Intraday chart data for CADJPY to the file CADJPY.scid. Service: fxcm | 2021-03-29 09:45:08.121
HD Request # 5 | Download start date-time: 2021-03-29 08:58:16.000000. File last date-time: 2021-03-29 08:58:16.254000 | 2021-03-29 09:45:08.122
HD Request # 5 | Using server: ds12.sierracharts.com port 10150 | 2021-03-29 09:45:08.122
Socket (2) | Creating socket. | 2021-03-29 09:45:08.122
Socket (2) | New receive buffer size: 5242880 | 2021-03-29 09:45:08.122
Socket (2) | Connecting to IP: 204.15.197.14. | 2021-03-29 09:45:08.122
HD Request # 5 | Setting DTC encoding to Binary VLS | 2021-03-29 09:45:08.543
HD Request # 5 | Sending historical data logon request message. | 2021-03-29 09:45:08.543
HD Request # 5 | Requesting Intraday data. Start date-time: 2021-03-29 08:58:16. Record interval: 0. Symbol: CADJPY | 2021-03-29 09:45:09.227
HD Request # 5 | Decompressing data. | 2021-03-29 09:45:09.444
HD Request # 5 | Receiving Intraday data for CADJPY starting at 2021-03-29 08:58:16.041000 | 2021-03-29 09:45:09.967
Socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-03-29 09:45:57.017
Socket (2) | Socket gracefully closed by remote side. | 2021-03-29 09:45:57.017
Socket (2) | CloseSocket call. | 2021-03-29 09:45:57.017
Socket (0) | CloseSocket call. | 2021-03-29 09:45:57.017
Socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-03-29 09:45:57.017
Socket (2) | Closed. | 2021-03-29 09:45:57.017
HD Request # 5 | Error downloading historical Intraday data for CADJPY. The network socket has been closed. Retrying download. | 2021-03-29 09:45:57.017
Added historical Intraday data request for CADJPY to the queue. | 2021-03-29 09:45:57.017
Triggering next historical data download in queue. | 2021-03-29 09:45:57.017
Historical data download thread signaled to stop. | 2021-03-29 09:45:57.017
HD Request # 5 | Timestamp of first Intraday data file record written: 2021-03-29 08:58:17.352000 | 2021-03-29 09:45:57.017
HD Request # 5 | Received 308 records from 2021-03-29 08:58:16.041000 to 2021-03-29 09:00:49.856000 (2.6 minutes) and wrote 303 records for CADJPY | 2021-03-29 09:45:57.018
HD Request # 5 | Completion time: 49s | 2021-03-29 09:45:57.023
HD Request # 6 | Downloading Intraday chart data for CADJPY to the file CADJPY.scid. Service: fxcm | 2021-03-29 09:45:57.024
HD Request # 6 | Download start date-time: 2021-03-29 09:00:49.000000. File last date-time: 2021-03-29 09:00:49.856000 | 2021-03-29 09:45:57.024
HD Request # 6 | Using server: ds4.sierracharts.com port 10149 | 2021-03-29 09:45:57.024
Socket (2) | Creating socket. | 2021-03-29 09:45:57.024
Socket (2) | New receive buffer size: 5242880 | 2021-03-29 09:45:57.024
Socket (2) | Connecting to IP: 192.81.56.146. | 2021-03-29 09:45:57.025
HD Request # 6 | Setting DTC encoding to Binary VLS | 2021-03-29 09:45:58.069
HD Request # 6 | Sending historical data logon request message. | 2021-03-29 09:45:58.069
HD Request # 6 | Requesting Intraday data. Start date-time: 2021-03-29 09:00:49. Record interval: 0. Symbol: CADJPY | 2021-03-29 09:45:58.803
HD Request # 6 | Decompressing data. | 2021-03-29 09:45:59.007
Socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-03-29 09:45:59.225
HD Request # 6 | Receiving Intraday data for CADJPY starting at 2021-03-29 09:00:49.024000 | 2021-03-29 09:45:59.226
Socket (2) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-03-29 09:45:59.227
Socket (2) | CloseSocket call. | 2021-03-29 09:45:59.227
Socket (0) | CloseSocket call. | 2021-03-29 09:45:59.227
Socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-03-29 09:45:59.227
Socket (2) | Closed. | 2021-03-29 09:45:59.227
HD Request # 6 | Error downloading historical Intraday data for CADJPY. The network socket has been closed. Retrying download. | 2021-03-29 09:45:59.232
Historical data download thread signaled to stop. | 2021-03-29 09:45:59.232
HD Request # 6 | Timestamp of first Intraday data file record written: 2021-03-29 09:00:49.919000 | 2021-03-29 09:45:59.232
HD Request # 6 | Received 136 records from 2021-03-29 09:00:49.024000 to 2021-03-29 09:01:42.351000 (53.3 seconds) and wrote 130 records for CADJPY | 2021-03-29 09:45:59.232
HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2021-03-29 06:01:42.351000 | 2021-03-29 09:45:59.241
Added 241 Time and Sales records to Intraday data file for CADJPY after download. | 2021-03-29 09:45:59.241
HD Request # 6 | Completion time: 2s | 2021-03-29 09:45:59.248
HD Request # 6 | Intraday data download complete for CADJPY. Unique request ID: 35 | 2021-03-29 09:45:59.248
Removing historical data download ID 35. | 2021-03-29 09:45:59.248
Real-time Intraday chart data file updates started for CADJPY | 2021-03-29 09:45:59.248
Intraday chart data file opened for CADJPY | 2021-03-29 09:45:59.248
HD Request # 6 | Enabling Intraday chart updating for symbol. | 2021-03-29 09:45:59.248
[2021-03-29 06:59:38]
I just saw this line in the log and I tried
telnet ds4.sierracharts.com 10149
telnet ds4.sierracharts.com 10150
telnet ds4.sierracharts.com 80
commands in Command Prompt.
All ports are opened, I saw only a cursor after executing them. So I guess the problem is on SC side.
[2021-03-29 07:29:19]
Also I saw these messages in the log while updating to a newer SC version for the last couple of updates.
https://i.imgur.com/FYXaYmw.png https://i.imgur.com/x5JWwDZ.png
Date Time Of Last Edit: 2021-03-29 07:32:36
[2021-03-29 16:18:06]
John - SC Support - Posts: 48114
With regards to your data, you have multiple of the following errors in your log:
So you definitely have a connectivity problem of some kind. Refer to the following:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
The errors when updating are telling you the same thing, there is a connectivity issue. Although that one is related to HTTP requests, therefore also review the following:
[2021-03-29 18:10:56]
I tried to do this: Data/Trading Service Connection and Symbol Issues: 1.8. Checking Connection Quality to Remote Server by Using Ping
I used two different internet connections, but the result is the same in both cases: https://i.imgur.com/ISc6JDu.png
Are you sure it's not a problem on your side with something, maybe some connections need to be reseted or refreshed?
I see other support requests re this issue with slow/delayed connection, like this one: Binance - Slow data download ETH and BTC
And the 1-st time I noticed it was as well around 1 week ago, when I tried to update to a newer version, it was way slower and I saw same messages I showed you in post #11.
[2021-03-29 18:18:11]
Or here: Bitmex Intraday data not loading more than 2 weeks on CQG WebAPI
He was using the same server ds12.sierracharts.com and had the same Windows error code 10053 today.
[2021-03-29 18:37:19]
Btw, not all ping tests fail.
Pinging ds1.sierracharts.com, ds3.sierracharts.com, ds5.sierracharts.com, ds7.sierracharts.com servers were fully successful.
Date Time Of Last Edit: 2021-03-29 18:39:31
[2021-03-30 19:03:29]
I changed my internet connection one more time this morning, and it seems like all downloads came back to normal so far. I don't see 10053 error codes anymore.
But my ping tests still fail, 100% loss. I see in message log SC uses ds4.sierracharts.com and ds12.sierracharts.com servers for historical data downloads.
This section Data/Trading Service Connection and Symbol Issues: 1.8. Checking Connection Quality to Remote Server by Using Ping says:
A useful way to check the quality of the connectivity between your computer and the server being connected to, is by using the network Ping command from the operating system command line. You will use the server address name with the Ping command.
So it's not good, that my ping tests fail, right? Can you try ping tests to these servers too?
And the link in this line 'Refer to this Internet article for instructions to use Ping.' is dead.
Date Time Of Last Edit: 2021-03-30 21:14:24
[2021-04-01 18:39:38]
[2021-04-01 19:12:50]
That is because those servers are not setup to respond to ping requests.
[2021-04-01 19:42:44]
Why do you suggest checking the quality of the connectivity between computer and the server by using ping command then?
[2021-04-01 21:09:04]
There are some servers, such as ds1.sierracharts.com that is mentioned in that section of documentation, that does support a ping.
