Date/Time: Mon, 05 Oct 2026 05:20:05 +0000
Looking for insight into how to connect with
View Count: 850
[2021-03-26 22:16:50]
mhren - Posts: 12
I was a long time user of SierraChart years ago and am looking to start using it again to support my trading. I have a few brokerage accounts but it seems some are no longer supported in the later versions of Sierra (specifically TD Ameritrade). Another one that I have is with TransAct/Infinity futures. Years ago I was able to use this account in Sierra Charts but today I am getting a vague (-1) error when attempting to connect. This is important to me since I am a non-professional trader and need at least one connection to get the appropriate data feed rates (since it seems signing a doc isn't good enough ;-) )....
I have attached the message log since this might help, but can you let me know what I might need to do in order to get the TransAct WS connection to work in the latest version of SC?
Thank you !!!!
-- mike
... message log ...
Software version: 2239 64-bit | 2021-03-26 20:02:29.821
Primary Thread ID: 264 | 2021-03-26 20:02:29.821
Usage end date: 2021-04-25 | 2021-03-26 20:02:29.821
Enabled for: Sierra Chart Historical Data Service. | 2021-03-26 20:02:29.821
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-03-26 20:02:29.821
Enabled for: Delayed Denali Exchange Data Feed. | 2021-03-26 20:02:29.821
Enabled for exchange2: CME (Trading Account Required) | 2021-03-26 20:02:29.821
Enabled for exchange2: CBOT (Trading Account Required) | 2021-03-26 20:02:29.821
Enabled for exchange2: COMEX (Trading Account Required) | 2021-03-26 20:02:29.821
Enabled for exchange2: NYMEX (Trading Account Required) | 2021-03-26 20:02:29.821
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-03-26 20:02:29.821
Current selected Data/Trading service: SC Data - All Services | 2021-03-26 20:02:29.821
Custom symbol settings values: enabled | 2021-03-26 20:02:29.821
Chart Update Interval: 500 | 2021-03-26 20:02:29.821
Intraday Data Storage Time Unit: 1 | 2021-03-26 20:02:29.821
Time Zone: +00:00:00 (UTC+00) | 2021-03-26 20:02:29.821
2021-03-26 20:02:29 Local computer time in UTC | 2021-03-26 20:02:29.821
2021-03-26 20:02:29 Local computer time in SC Time Zone | 2021-03-26 20:02:29.821
2021-03-26 18:06:27 Server time in UTC | 2021-03-26 20:02:29.821
Local computer UTC time and Server UTC time difference: 2 seconds. | 2021-03-26 20:02:29.821
Program path: C:\SierraChart\ | 2021-03-26 20:02:29.821
Data Files path: C:\SierraChart\Data\ | 2021-03-26 20:02:29.821
OS Version Number: 10.0 | 2021-03-26 20:02:29.823
Locale Setting: C | 2021-03-26 20:02:29.823
DLLs: MhrenStudies_64.dll, UserContributedStudies_64.dll | 2021-03-26 20:02:29.824
Allowed protected custom studies: | 2021-03-26 20:02:29.825
SC Data - All Services | Disconnected. | 2021-03-26 20:02:45.960
SC Data - All Services | Disconnected. | 2021-03-26 20:02:46.091
Checking for new symbol settings. Requested symbol settings MD5 for service code transact.trading. Request ID: 6. | 2021-03-26 20:02:46.108
Current selected Data/Trading service: TransAct WS | 2021-03-26 20:02:46.108
Symbol settings MD5 received. Request ID: 6. | 2021-03-26 20:02:47.172
Requested symbol settings for service code transact.trading. Request ID: 7. | 2021-03-26 20:02:47.173
Symbol settings received. Request ID: 7. | 2021-03-26 20:02:48.126
TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2021-03-26 20:02:56.912
Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2021-03-26 20:02:56.912
Auth Websocket socket (2) | Creating socket. Using TLS 1.2. | 2021-03-26 20:02:56.918
Auth Websocket socket (2) | New receive buffer size: 5242880 | 2021-03-26 20:02:56.921
Auth Websocket socket (2) | Connecting to IP: 208.97.219.30. | 2021-03-26 20:02:56.921
Auth Websocket | Opening WebSocket. | 2021-03-26 20:02:56.966
Auth Websocket | Sending WebSocket handshake. | 2021-03-26 20:02:56.966
Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-03-26 20:02:57.147
Auth Websocket | Server header | Upgrade: WebSocket | 2021-03-26 20:02:57.147
Auth Websocket | Server header | Connection: Upgrade | 2021-03-26 20:02:57.147
Auth Websocket | Server header | Sec-WebSocket-Accept: EDZ1hqJuVc6lfumieWI5uia77BQ= | 2021-03-26 20:02:57.147
Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2021-03-26 20:02:57.147
Auth Websocket | Server header | | 2021-03-26 20:02:57.147
Auth Websocket | Web socket state is now open. | 2021-03-26 20:02:57.147
TransAct WS | Sending account logon message. Live | 2021-03-26 20:02:57.147
TransAct WS | Account logon error: -1(-1) | 2021-03-26 20:02:57.236
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-03-26 20:02:57.236
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-03-26 20:02:57.236
TransAct WS | Session key cleared | 2021-03-26 20:02:57.515
Auth Websocket socket (2) | CloseSocket call. | 2021-03-26 20:02:57.515
Auth Websocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-03-26 20:02:57.515
Auth Websocket | WebSocket closed. | 2021-03-26 20:02:57.515
TransAct WS | Disconnected. | 2021-03-26 20:02:57.515
Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-03-26 20:02:57.515
Auth Websocket socket (2) | Write has completed. Shutdown being performed. | 2021-03-26 20:02:57.552
Auth Websocket socket (2) | Shutdown started. Waiting for graceful close. | 2021-03-26 20:02:57.553
[2021-03-29 13:47:42]
John - SC Support - Posts: 48095
This is the specific error:
That error is a TransAct error. You need to let them know about it for your account and they can take care of it.
Date Time Of Last Edit: 2021-03-29 13:48:27
