Date/Time: Thu, 10 Sep 2026 09:01:31 +0000
Since updating to v. 2243
View Count: 820
| [2021-03-26 18:42:53] |
| Using SC Since 2020 - Posts: 146 |
Charts do no respond when clicking on linked quoteboard. I've closed the majority of charts and verified link settings. CPU performance is not affected (very low, sub 10% of memory etc.). I've restarted SC. Issue only started since downloading the latest version (2243). This is preventing me from quickly changing symbols. Very important for me. Thank you Date Time Of Last Edit: 2021-03-26 18:48:55
| [2021-03-26 18:50:13] |
This is no longer a huge issue for me. Rolling back to version 2240 immediately solved the chart linking unresponsive issue for me. I am interested to know if v.2243 had a "link" bug so that if fixed, I can update to the latest version. Thank you I run 2 instances of SC. One for IBKR, and another for Futures trading. The IBKR version is running v.2243, and the futures is running 2240. In 2240 links work as normal, and v.2243 for IBKR is unresponsive. Rolling that back now to 2240. Update: rolling back IBRK second instance of SC to v.2240 fixes link issue. Date Time Of Last Edit: 2021-03-26 19:07:41
| [2021-03-26 19:01:09] |
We are checking on this now.
