Date/Time: Tue, 25 Feb 2025 16:17:51 +0000
Incomplet data feed for the symbol F.US.BP6M21 Inbox
View Count: 860
[2021-03-23 16:42:10]
bogdan balas - Posts: 8
Dear Sirs,
I have an active pack 5 subscrision and a trading account on AMP with a CQG data feed. On F.US.BP6M21 symbol with a chart that has TPO studies I see only the data from 17,03,2021. I can not scroll on time axis. The same setup I have for F.US.EU6M21 symbol and is working fine I can scroll the historical data.
If I make an upgrade to Pack 11 can I trade with AMP account?
Thank you,
Regards,
Bogdan
imageF.US.BP6M21 picture.jpg / V - Attached On 2021-03-23 16:40:45 UTC - Size: 155.93 KB - 225 views
[2021-03-23 16:48:40]
Yes, we definitely do recommend using the Denali Exchange Data Feed and replacing the data from CQG:
Using the Denali data feed will solve the historical data limitations.
Date Time Of Last Edit: 2021-03-23 16:49:14
[2021-03-26 13:07:40]
Dear Sirs,
Please tell me how can I make the transfer to Sierra Data Feed and how much is the monthly cost? Pack 11+ AMP account for execution? I want to trade only CME futures contracts, 6B and MiniSP.
Thank you,
B
Date Time Of Last Edit: 2021-03-26 13:10:02
[2021-03-26 14:57:23]
John - SC Support - Posts: 38158
Do you need Market Depth data for those symbols?
[2021-03-26 15:21:33]
No!
B
[2021-03-26 15:37:44]
Then you would want the following setup:
- Package 11: $46.00 USD per month
- Full CME Group (CME, CBOT, COMEX, NYMEX) for nonprofessional Trading accounts: $3.25 USD per month
Total: $49.25 USD per month
Refer to the Setup Instructions for the Denali Exchange Data Feed here:
[2021-03-26 16:18:42]
So,
I would like to purchase Pack 11 for 6 month 36,8$/monthv+ 3,25 USD/month CME real data+ historical data. Other costs like rutting orders fees will be charged /transaction?
What I need to do in order to quit the CQG and change to your service. It is ok to activate pack 11 ( upgrade mean to pay the difference between pack 5 and 11). I need to contact AMP to announce that or after activated pack 11 you can help me with setting the account.
Thank you,
B
[2021-03-26 17:24:21]
If you want to use the Sierra Chart Order Routing Service, then you would need to change to a broker that supports that service. You can find a list of brokers at Step #2 here:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions
In general, you will always have transaction fees for your trades. You would need to check with whatever broker you use to find out what they charge.
In order to get the Denali Exchange Data Feed, follow these instructions:
Those instructions include information about changing your Package, so you can do that at that point in the instructions.
You do not need to contact AMP about anything with regards to changing packages or adding data.
[2021-04-09 06:43:04]
Dear Sir,
I have upgraded to Denali Exchange data feed and every time when I start the platform the last bar from foot print is not completed and the price line is showing to be in a outside zone of the footprint bar. See picture attached. What I am doing wrong? See http://www.sierrachart.com/image.php?Image=1617950412772.png
Thanks,
Bogdan
imageSierraChart2.jpg / V - Attached On 2021-04-09 06:33:47 UTC - Size: 279.53 KB - 202 views
[2021-04-09 11:49:39]
Reconnect to the data feed:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2021-04-19 06:18:01]
Software version: 2245 64-bit | 2021-04-19 07:14:05.208
Primary Thread ID: 9852 | 2021-04-19 07:14:05.208
Usage end date: 2021-06-02 | 2021-04-19 07:14:05.208
Enabled for: Advanced Features 2. | 2021-04-19 07:14:05.208
Enabled for: Sierra Chart Historical Data Service. | 2021-04-19 07:14:05.208
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-04-19 07:14:05.208
Enabled for: Delayed Denali Exchange Data Feed. | 2021-04-19 07:14:05.208
Enabled for exchange2: CME (Trading Account Required) | 2021-04-19 07:14:05.208
Enabled for exchange2: CBOT (Trading Account Required) | 2021-04-19 07:14:05.208
Enabled for exchange2: COMEX (Trading Account Required) | 2021-04-19 07:14:05.208
Enabled for exchange2: NYMEX (Trading Account Required) | 2021-04-19 07:14:05.208
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-04-19 07:14:05.208
Current selected Data/Trading service: SC Data - All Services | 2021-04-19 07:14:05.208
Custom symbol settings values: enabled | 2021-04-19 07:14:05.208
Chart Update Interval: 500 | 2021-04-19 07:14:05.208
Intraday Data Storage Time Unit: 0 | 2021-04-19 07:14:05.208
Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2021-04-19 07:14:05.208
2021-04-19 06:14:05 Local computer time in UTC | 2021-04-19 07:14:05.208
2021-04-19 07:14:05 Local computer time in SC Time Zone | 2021-04-19 07:14:05.208
2021-04-19 05:46:07 Server time in UTC | 2021-04-19 07:14:05.208
Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-04-19 07:14:05.208
Program path: C:\SierraChart\ | 2021-04-19 07:14:05.208
Data Files path: C:\SierraChart\Data\ | 2021-04-19 07:14:05.208
OS Version Number: 10.0 | 2021-04-19 07:14:05.208
Locale Setting: C | 2021-04-19 07:14:05.208
DLLs: UserContributedStudies_64.dll | 2021-04-19 07:14:05.210
Allowed protected custom studies: | 2021-04-19 07:14:05.210
File >> Disconnect selected. | 2021-04-19 07:14:11.384
SC Data - All Services | Waiting for socket receive thread to end | 2021-04-19 07:14:11.392
DTC Client socket (1) | CloseSocket call. | 2021-04-19 07:14:11.392
SC Data - All Services | Disconnected from the server. | 2021-04-19 07:14:11.392
SC Data - All Services | Disconnected. | 2021-04-19 07:14:11.392
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-04-19 07:14:11.393
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-04-19 07:14:33.295 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-04-19 07:14:33.296
DTC Client socket (1) | Closed. | 2021-04-19 07:14:33.296
SC Data - All Services | Connected to server complete. | 2021-04-19 07:15:45.093
Triggering next historical data download in queue. | 2021-04-19 07:15:45.094
No download requests in the queue to start downloads for. | 2021-04-19 07:15:45.101
Mapping MESM21-CME to MESM21. Service code: cme | 2021-04-19 07:15:45.334
SC Data - All Services | Starting real-time market data updates for: MESM21-CME (MESM21). ID: 1 Service code: cme | 2021-04-19 07:15:45.334
SC Data - All Services | Connecting to the server ds5-2.sierracharts.com. Port 10048 | 2021-04-19 07:15:45.334
SC Data - All Services | Requesting security definition data for: MESM21-CME (MESM21). ID: 1 | 2021-04-19 07:15:45.334
Added historical Intraday data request for MESM21-CME to the queue. | 2021-04-19 07:15:45.334
Intraday data recording state for symbol MESM21-CME is set to download 'Pending'. | 2021-04-19 07:15:45.334
Triggering next historical data download in queue. | 2021-04-19 07:15:45.334
Delaying start of download for MESM21-CME | 2021-04-19 07:15:45.335
Mapping 6BM21-CME to 6BM21. Service code: cme | 2021-04-19 07:15:45.352
SC Data - All Services | Starting real-time market data updates for: 6BM21-CME (6BM21). ID: 2 Service code: cme | 2021-04-19 07:15:45.352
SC Data - All Services | Requesting security definition data for: 6BM21-CME (6BM21). ID: 2 | 2021-04-19 07:15:45.352
Added historical Intraday data request for 6BM21-CME to the queue. | 2021-04-19 07:15:45.352
Intraday data recording state for symbol 6BM21-CME is set to download 'Pending'. | 2021-04-19 07:15:45.352
Triggering next historical data download in queue. | 2021-04-19 07:15:45.352
DTC Client socket (1) | Creating socket. | 2021-04-19 07:15:45.409
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-04-19 07:15:45.409
DTC Client socket (1) | Connecting to IP: 51.195.180.15. | 2021-04-19 07:15:45.409
Mapping 6EM21-CME to 6EM21. Service code: cme | 2021-04-19 07:15:45.451
SC Data - All Services | Starting real-time market data updates for: 6EM21-CME (6EM21). ID: 3 Service code: cme | 2021-04-19 07:15:45.451
SC Data - All Services | Requesting security definition data for: 6EM21-CME (6EM21). ID: 3 | 2021-04-19 07:15:45.451
Added historical Intraday data request for 6EM21-CME to the queue. | 2021-04-19 07:15:45.451
Intraday data recording state for symbol 6EM21-CME is set to download 'Pending'. | 2021-04-19 07:15:45.451
Triggering next historical data download in queue. | 2021-04-19 07:15:45.451
SC Data - All Services | Network connection to server complete. | 2021-04-19 07:15:45.493
SC Data - All Services | Starting socket receive thread. | 2021-04-19 07:15:45.493
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-04-19 07:15:45.493
SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-04-19 07:15:45.571
SC Data - All Services | Sending logon request message. | 2021-04-19 07:15:45.571
SC Data - All Services | Received logon response. | 2021-04-19 07:15:46.057
SC Data - All Services | Server Name: SC Realtime Server. | 2021-04-19 07:15:46.057
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-04-19 07:15:46.057
SC Data - All Services | Successfully connected. | 2021-04-19 07:15:46.057
SC Data - All Services | Trading is not supported. | 2021-04-19 07:15:46.057
SC Data - All Services | Restarting real-time data updates for symbol: 6BM21-CME -> 6BM21 | 2021-04-19 07:15:46.057
SC Data - All Services | Restarting real-time data updates for symbol: 6EM21-CME -> 6EM21 | 2021-04-19 07:15:46.057
SC Data - All Services | Restarting real-time data updates for symbol: MESM21-CME -> MESM21 | 2021-04-19 07:15:46.057
SC Data - All Services | Received security definition for symbol 6BM21-CME | 2021-04-19 07:15:46.214
SC Data - All Services | Received security definition for symbol 6EM21-CME | 2021-04-19 07:15:46.214
SC Data - All Services | Received security definition for symbol MESM21-CME | 2021-04-19 07:15:46.214
HD Request # 8 | Downloading Intraday chart data for MESM21-CME to the file MESM21-CME.scid. Service: cme | 2021-04-19 07:15:51.235
HD Request # 8 | Download start date-time: 2021-04-19 07:13:58.000000. File last date-time: 2021-04-19 07:13:58.981000 | 2021-04-19 07:15:51.238
HD Request # 8 | Using server: ds21.sierracharts.com port 10150 | 2021-04-19 07:15:51.238
Socket (2) | Creating socket. | 2021-04-19 07:15:51.238
Socket (2) | New receive buffer size: 5242880 | 2021-04-19 07:15:51.239
Socket (2) | Connecting to IP: 216.1.90.129. | 2021-04-19 07:15:51.239
HD Request # 8 | Setting DTC encoding to Binary VLS | 2021-04-19 07:15:51.544
HD Request # 8 | Sending historical data logon request message. | 2021-04-19 07:15:51.544
HD Request # 8 | Requesting Intraday data. Start date-time: 2021-04-19 07:13:58. Record interval: 0. Symbol: MESM21 | 2021-04-19 07:15:52.142
HD Request # 8 | Decompressing data. | 2021-04-19 07:15:52.279
HD Request # 8 | Receiving Intraday data for MESM21-CME starting at 2021-04-19 07:13:58.981000 | 2021-04-19 07:15:52.280
Socket (2) | CloseSocket call. | 2021-04-19 07:15:52.282
Socket (2) | Shutdown started. Waiting for graceful close. | 2021-04-19 07:15:52.282
Historical data download thread signaled to stop. | 2021-04-19 07:15:52.282
HD Request # 8 | Timestamp of first Intraday data file record written: 2021-04-19 07:14:13.314000 | 2021-04-19 07:15:52.282
HD Request # 8 | Received 53 records from 2021-04-19 07:13:58.981000 to 2021-04-19 07:15:47.126000 (108.1 seconds) and wrote 52 records for MESM21-CME | 2021-04-19 07:15:52.283
HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2021-04-19 06:15:47.126000 | 2021-04-19 07:15:52.285
Added 3 Time and Sales records to Intraday data file for MESM21-CME after download. | 2021-04-19 07:15:52.285
HD Request # 8 | Completion time: 1s | 2021-04-19 07:15:52.286
HD Request # 8 | Intraday data download complete for MESM21-CME. Unique request ID: 7 | 2021-04-19 07:15:52.286
Removing historical data download ID 7. | 2021-04-19 07:15:52.286
Real-time Intraday chart data file updates started for MESM21-CME | 2021-04-19 07:15:52.286
Intraday chart data file opened for MESM21-CME | 2021-04-19 07:15:52.286
HD Request # 8 | Enabling Intraday chart updating for symbol. | 2021-04-19 07:15:52.286
Triggering next historical data download in queue. | 2021-04-19 07:15:52.286
HD Request # 9 | Downloading Intraday chart data for 6BM21-CME to the file 6BM21-CME.scid. Service: cme | 2021-04-19 07:15:52.286
HD Request # 9 | Download start date-time: 2021-04-19 07:13:56.000000. File last date-time: 2021-04-19 07:13:56.717001 | 2021-04-19 07:15:52.288
HD Request # 9 | Using server: ds23.sierracharts.com port 10149 | 2021-04-19 07:15:52.288
Socket (3) | Creating socket. | 2021-04-19 07:15:52.289
Socket (3) | New receive buffer size: 5242880 | 2021-04-19 07:15:52.289
Socket (3) | Connecting to IP: 216.1.90.130. | 2021-04-19 07:15:52.289
Socket (2) | Socket gracefully closed by remote side. | 2021-04-19 07:15:52.430
Socket (2) | Closed. | 2021-04-19 07:15:52.430
HD Request # 9 | Setting DTC encoding to Binary VLS | 2021-04-19 07:15:52.581
HD Request # 9 | Sending historical data logon request message. | 2021-04-19 07:15:52.581
HD Request # 9 | Requesting Intraday data. Start date-time: 2021-04-19 07:13:56. Record interval: 0. Symbol: 6BM21 | 2021-04-19 07:15:53.195
HD Request # 9 | Decompressing data. | 2021-04-19 07:15:53.348
HD Request # 9 | Receiving Intraday data for 6BM21-CME starting at 2021-04-19 07:13:56.717000 | 2021-04-19 07:15:53.349
Socket (3) | CloseSocket call. | 2021-04-19 07:15:53.350
Socket (3) | Shutdown started. Waiting for graceful close. | 2021-04-19 07:15:53.350
Historical data download thread signaled to stop. | 2021-04-19 07:15:53.351
HD Request # 9 | Timestamp of first Intraday data file record written: 2021-04-19 07:14:14.983000 | 2021-04-19 07:15:53.351
HD Request # 9 | Received 45 records from 2021-04-19 07:13:56.717000 to 2021-04-19 07:15:50.408002 (113.7 seconds) and wrote 43 records for 6BM21-CME | 2021-04-19 07:15:53.351
HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2021-04-19 06:15:50.408002 | 2021-04-19 07:15:53.354
HD Request # 9 | Completion time: 1s | 2021-04-19 07:15:53.354
HD Request # 9 | Intraday data download complete for 6BM21-CME. Unique request ID: 8 | 2021-04-19 07:15:53.354
Removing historical data download ID 8. | 2021-04-19 07:15:53.354
Real-time Intraday chart data file updates started for 6BM21-CME | 2021-04-19 07:15:53.354
Intraday chart data file opened for 6BM21-CME | 2021-04-19 07:15:53.354
HD Request # 9 | Enabling Intraday chart updating for symbol. | 2021-04-19 07:15:53.354
Triggering next historical data download in queue. | 2021-04-19 07:15:53.354
HD Request # 10 | Downloading Intraday chart data for 6EM21-CME to the file 6EM21-CME.scid. Service: cme | 2021-04-19 07:15:53.355
HD Request # 10 | Download start date-time: 2021-04-19 07:14:11.000000. File last date-time: 2021-04-19 07:14:11.018000 | 2021-04-19 07:15:53.356
HD Request # 10 | Using server: ds21.sierracharts.com port 10150 | 2021-04-19 07:15:53.357
Socket (2) | Creating socket. | 2021-04-19 07:15:53.357
Socket (2) | New receive buffer size: 5242880 | 2021-04-19 07:15:53.357
Socket (2) | Connecting to IP: 216.1.90.129. | 2021-04-19 07:15:53.357
Socket (3) | Socket gracefully closed by remote side. | 2021-04-19 07:15:53.490
Socket (3) | Closed. | 2021-04-19 07:15:53.490
HD Request # 10 | Setting DTC encoding to Binary VLS | 2021-04-19 07:15:53.648
HD Request # 10 | Sending historical data logon request message. | 2021-04-19 07:15:53.648
HD Request # 10 | Requesting Intraday data. Start date-time: 2021-04-19 07:14:11. Record interval: 0. Symbol: 6EM21 | 2021-04-19 07:15:53.801
HD Request # 10 | Decompressing data. | 2021-04-19 07:15:53.954
HD Request # 10 | Receiving Intraday data for 6EM21-CME starting at 2021-04-19 07:14:11.018000 | 2021-04-19 07:15:53.955
Socket (2) | CloseSocket call. | 2021-04-19 07:15:53.956
Socket (2) | Shutdown started. Waiting for graceful close. | 2021-04-19 07:15:53.957
Historical data download thread signaled to stop. | 2021-04-19 07:15:53.958
HD Request # 10 | Timestamp of first Intraday data file record written: 2021-04-19 07:14:14.886000 | 2021-04-19 07:15:53.958
HD Request # 10 | Received 66 records from 2021-04-19 07:14:11.018000 to 2021-04-19 07:15:54.411000 (103.4 seconds) and wrote 65 records for 6EM21-CME | 2021-04-19 07:15:53.958
HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2021-04-19 06:15:54.411000 | 2021-04-19 07:15:53.961
HD Request # 10 | Completion time: 0s | 2021-04-19 07:15:53.961
HD Request # 10 | Intraday data download complete for 6EM21-CME. Unique request ID: 9 | 2021-04-19 07:15:53.961
Removing historical data download ID 9. | 2021-04-19 07:15:53.961
Real-time Intraday chart data file updates started for 6EM21-CME | 2021-04-19 07:15:53.961
Intraday chart data file opened for 6EM21-CME | 2021-04-19 07:15:53.961
HD Request # 10 | Enabling Intraday chart updating for symbol. | 2021-04-19 07:15:53.961
Triggering next historical data download in queue. | 2021-04-19 07:15:53.961
No download requests in the queue to start downloads for. | 2021-04-19 07:15:53.962
Socket (2) | Socket gracefully closed by remote side. | 2021-04-19 07:15:54.107
Socket (2) | Closed. | 2021-04-19 07:15:54.108
Opened cached Intraday file: C:\SierraChart\Data\MESM21-CME.scid. Thread ID: 2524 | 2021-04-19 07:15:57.782
Opened cached Intraday file: C:\SierraChart\Data\6BM21-CME.scid. Thread ID: 2524 | 2021-04-19 07:15:57.783
Opened cached Intraday file: C:\SierraChart\Data\6EM21-CME.scid. Thread ID: 2524 | 2021-04-19 07:16:28.238
[2021-04-19 06:32:27]
http://www.sierrachart.com/image.php?Image=1618813897292.png
[2021-04-19 07:43:25]
Dear Sierras,
I have found the issue Chart/Chart Settings/New Bar at Session Start.
You are the best
Regards,
B
[2021-04-21 04:25:41]
We understand there are no further questions here.
