Date/Time: Mon, 24 Feb 2025 18:15:11 +0000
wakamaxida why my test ID can not login? thanks
View Count: 527
[2021-03-19 12:37:58] |
User178924 - Posts: 2 |
I just opened my account and when I try to connect I get a Service connection Error. I try to change the service settings, but that didn't work as well. Not sure how can I revert the service settings back to what it was. I've attached the screenshots of the error : Reading Internal Order ID file. | 2021-03-19 19:33:14.623 Reading Trade Orders file. | 2021-03-19 19:33:14.747 Reading Trade Positions file. | 2021-03-19 19:33:14.747 Reading Trade Account Data files. | 2021-03-19 19:33:14.748 UDPListener (1564). Port 22904 | Listening on UDP port 22904. | 2021-03-19 19:33:14.784 Software version: 2239 64-bit | 2021-03-19 19:33:14.784 Primary Thread ID: 9840 | 2021-03-19 19:33:14.784 Usage end date: 2021-04-02 | 2021-03-19 19:33:14.784 Usage time has ended. Sierra Chart is in Free mode. Features are restricted. | 2021-03-19 19:33:14.784 To purchase usage time, select 'Help >> Add Usage Credit' on the menu. | 2021-03-19 19:33:14.784 * Allow Support for Sierra Chart Data Feeds is enabled. | 2021-03-19 19:33:14.784 Current selected Data/Trading service: SC Data - All Services | 2021-03-19 19:33:14.784 Custom symbol settings values: enabled | 2021-03-19 19:33:14.784 Chart Update Interval: 500 | 2021-03-19 19:33:14.784 Intraday Data Storage Time Unit: 0 | 2021-03-19 19:33:14.784 Time Zone: +08:00:00 (HKT+08) | 2021-03-19 19:33:14.784 2021-03-19 11:33:14 Local computer time in UTC | 2021-03-19 19:33:14.784 2021-03-19 19:33:14 Local computer time in SC Time Zone | 2021-03-19 19:33:14.784 2021-03-19 11:33:10 Server time in UTC | 2021-03-19 19:33:14.784 Local computer UTC time and Server UTC time difference: 3 seconds. | 2021-03-19 19:33:14.784 Program path: D:\SierraChart\ | 2021-03-19 19:33:14.784 Data Files path: D:\SierraChart\Data\ | 2021-03-19 19:33:14.784 OS Version Number: 10.0 | 2021-03-19 19:33:14.784 Locale Setting: C | 2021-03-19 19:33:14.784 DLLs: GomMPPro_64.dll, GomOrderFlowPro_64.dll, UserContributedStudies_64.dll | 2021-03-19 19:33:14.785 Allowed protected custom studies: | 2021-03-19 19:33:14.785 DTC Protocol Server feature not enabled for Sierra Chart account. | 2021-03-19 19:33:14.785 * Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2021-03-19 19:33:14.785 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-03-19 19:33:14.842 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-03-19 19:33:15.105 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-03-19 19:33:15.106 Received 5 login tokens. | 2021-03-19 19:33:15.739 Symbol settings MD5 received. Request ID: 1. | 2021-03-19 19:33:17.101 Symbol settings are up-to-date for scdataallservices. | 2021-03-19 19:33:17.101 Connect to Data Feed | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2021-03-19 19:33:23.922 * Connect to Data Feed | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2021-03-19 19:35:27.810 * Connect to Data Feed | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2021-03-19 19:35:32.077 * Connect to Data Feed | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2021-03-19 19:37:00.637 * |
[2021-03-19 13:19:21] |
John - SC Support - Posts: 38140 |
We see that you have created multiple accounts that are on trial. We only allow one 15-day trial in a 12 month period per computer. We have reset your trial, so you can use the system again. Please choose one of the accounts that you created and only login with that one account, otherwise you will lock yourself out again. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-19 13:36:27] |
so I WANT BUY A MONEY id,HOU MUCH DO I LEAST COST? I WANT PAY FOR IT.
[2021-03-19 14:43:22] |
You will find the cost for the packages we have available here: Description of Service Packages and Pricing: Packages If you are interested in Real-Time data from us, then refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
