Date/Time: Tue, 04 Nov 2025 12:43:35 +0000
chart dom
View Count: 731
|   [2021-03-16 14:22:54]     |
| User318521 - Posts: 49 |
                Is there a way to filter the recent bid/ask volume on the chart dom. i would like to see only order the size of 10 plus and no all these little 1 and 2's constantly pop up
|   [2021-03-16 14:51:43]     |
| John - SC Support - Posts: 42737 |
                The only way to do that would be to filter the entire chart. Refer to the information here: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) And also refer to the following that may be interesting to you: Chart Settings: Combine Trades into Original Summary Trade (Data Feed and Exchange Specific) (Chart >> Chart Settings >> Chart Data >> Chart Data menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2021-06-27 04:23:42]     |
| User769783 - Posts: 195 |
                Would you guys be willing to develop a running total recent bid, ask volume counter if I pay for it? Thanks
