Date/Time: Mon, 10 Mar 2025 20:16:00 +0000
show/hide study buttons
View Count: 1672
[2021-03-10 06:52:39]
User884550 - Posts: 149
is it possible to create buttons on control bar to show and hide specific studies?
If not, can it be implemented somehow?
[2021-03-10 16:14:11]
John - SC Support - Posts: 38547
There is not support to Show/Hide specific studies, but you can setup Study Collections to be loaded, which would remove a set of studies and replace them with another set. Refer to the information here:
Control Bar: Control Bar Study Collection Buttons and Keyboard Shortcuts
[2021-04-07 12:58:13]
AKR - Posts: 525
have a look at this:
https://www.simplesystemtrading.com/hide-studies/
Only problem - question to SC is. I am using that study and crated a button on a custom control bar. As long the control bar is floating it works on also detached chart windows. as soon as I attach to eg left the control bar it does not work anyomore for detached charts. That is true for all buttons, not only the one using that study of frederik.
Any way I can solve that, as floating bar super anoying.
[2021-04-07 16:43:55]
You would need to attach that Control Bar to the detached chart. On the detached chart select Window >> Control Bar >> Control Bar # and then that control bar can be placed on that detached window where you want.
[2021-04-07 16:59:17]
AKR - Posts: 525
yes just figured out myself that is possible and wanted to delete post :-).
anyway THANK YOU (sorry)
[2022-04-13 10:55:50]
User92573 - Posts: 548
You could simply set the subgraphs within the study to toggle on/off, show/hide using an ACS_Button/s and the relevant code within that study?
You'd have to do this for each study though.
