Date/Time: Tue, 04 Nov 2025 04:41:37 +0000
Pulling and Stacking Levels
View Count: 835
|   [2021-03-08 09:36:24]     |
| Ben A - Posts: 123 |
                Hi,  Is there any way to have different levels of pulling/stacking in different DOMs? eg 1 level on one DOM and 5 on the other? If I change the setting it seems to change for all. Also, is it be possible with existing indicators or programmed to show the cumulative level of stacking at price level eg in a way similar to volume profile but for the delta of pulling/stacking? Many thanks!  |
|   [2021-03-08 10:05:52]     |
| Sierra_Chart Engineering - Posts: 21298 |
                The answer is no. It is a global setting. Also, is it be possible with existing indicators or programmed to show the cumulative level of stacking at price level eg in a way similar to volume profile but for the delta of pulling/stacking?  No this is not possible.
                Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing  |
