Date/Time: Tue, 04 Nov 2025 08:38:39 +0000
Sirra chart freezing & huge data lag on charts
View Count: 867
|   [2021-03-05 15:19:33]     |
| User287553 - Posts: 33 |
                Hi I'm having an issue where Sierra keeps on getting frozen, as it if it is not connected to the server properly and constant issue huge data lag in my charts (RANGE and minute charts). for e.g. on the MES price data on the chart just stalls for few seconds and then starts moving again. Please let me know if there are any issues that are happening with the Server i'm connected with? I simply cannot trade with so much lag, and the whole platform just freezing every few seconds. This was working ok few days ago but noticing this since yesterday. Please see file attached showing my connection to servers, and my chart interval settings. My internet connection is direct wired i.e. no wifi. And its very high speed top of the notch. My computer is also high end i7, 16GB RAM, 2.6 GHz CPU, so not sure why this is happening. JK AC 22839  |
Attachment Deleted.          |
|   [2021-03-05 16:01:36]     |
| John - SC Support - Posts: 42737 |
                This was responded to here: Computer Time Clock off For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2021-03-05 18:25:04]     |
                You definitively do not want to use a global chart update of all of 10 ms. Change that to 500 ms or higher and just use no lower than maybe 50 ms or 100 milliseconds for charts or trading DOMs that you want to be faster updating. Also refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-05 18:25:22
