Date/Time: Tue, 04 Nov 2025 14:59:38 +0000
Nasdaq Equities Feed
View Count: 935
|   [2021-02-23 02:46:52]     |
| User852559 - Posts: 40 |
                Hello, I have a few questions about the upcoming Nasdaq equities feed that you are building out. 1.) As far as the Level 2 data goes, will this be standard Level 2 or equivalent to Nasdaq Totalview? 2.) Will studies such as the market depth historical graph and bid/ask depth bars work with this data feed? 3.) What brokers will we be able to execute trades through using this feed? 4.) Do you have intentions of ever adding the other Level 2 books into this feed (ARCA/NYSE/etc.)? Thanks  |
|   [2021-02-23 14:44:09]     |
                We can only answer 1 and 2 for now and the answer is Yes. But the data feed will work with any supported Trading service including Interactive Brokers. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-23 14:44:46
|   [2021-02-28 19:20:17]     |
| User39772 - Posts: 311 |
                Hello, do I understand correct that there is a Equities feed available that includes Total View, so that it is possible now to trade Equities including orderbook and send orders to IB ? If yes, what configuration ins necessary, I did only see the Equities feed without Market Depth in your list ?  |
|   [2021-02-28 19:22:20]     |
                It is still in development. I believe they said maybe around April it will be released.
|   [2021-02-28 23:51:15]     |
                 do I understand correct that there is a Equities feed available that includes Total View, so that This is not yet available but in development. We hope to have it out in April but we will see.
                it is possible now to trade Equities including orderbook and send orders to IB ? Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-03-25 19:17:00]     |
                Will this new Level 2 feature be an add on to the existing Equity feed or will it be a total new feed. If the latter is the case, does it make sense to wait for the new feed or do you think it will be available early in April ?  |
|   [2021-05-26 19:59:55]     |
                Hello, is there any hope that the Lvl 2 feature is available in June and does it cover nasdaq total view ?
|   [2021-05-26 20:27:13]     |
| Sierra_Chart Engineering - Posts: 21301 |
                We do  think this data feed will be available in June. Sometime after. And it will include level  2 data.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-05-26 20:27:20
|   [2021-06-30 12:24:13]     |
                Hello, can you tell anything about the current status on Nasdaq lvl 2 data feed ?  |
|   [2021-06-30 14:07:27]     |
| John - SC Support - Posts: 42750 |
                All updates on this topic will be posted in a Sticky post on the Support Board. A lack of information means that there is nothing new for us to say and things have not changed status (i.e. it is still being worked on).
                 For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
