Date/Time: Thu, 19 Sep 2024 16:25:06 +0000
waiting to reconnect
View Count: 1734
[2014-02-26 13:58:05] |
User21339 - Posts: 61 |
cant connect to fxcm data feed. I can on another charting package - same computer, which makes me think its settings. help please. John Software version: 1091 | 2014-02-26 13:41:48 Usage end date: 2014-08-31 | 2014-02-26 13:41:48 Enabled for: Sierra Chart Historical Data Service. | 2014-02-26 13:41:48 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-02-26 13:41:48 Active service: FXCM FIX Trading | 2014-02-26 13:41:48 Time Zone: +00:00:00 (UTC+00) | 2014-02-26 13:41:48 2014-02-26 21:41:48 Local computer clock time | 2014-02-26 13:41:48 2014-02-26 13:41:48 GMT time | 2014-02-26 13:41:48 2014-02-26 13:41:48 Time zone adjusted time | 2014-02-26 13:41:48 Time difference to server time: 0 seconds. | 2014-02-26 13:41:48 Program path: C:\SierraChart\ | 2014-02-26 13:41:48 Data Files path: C:\SierraChart\Data\ | 2014-02-26 13:41:48 OS Version Number: 6.2 | 2014-02-26 13:41:48 Checking for new symbol settings for fxcm | 2014-02-26 13:41:48 Symbol settings are up-to-date for fxcm | 2014-02-26 13:41:49 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:41:53 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:41:53 The network socket is connected. | 2014-02-26 13:41:53 FXCM FIX: Sending the Logon message. | 2014-02-26 13:41:54 Socket closed. No error. | 2014-02-26 13:41:54 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:41:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:41:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:41:54 Disconnected from FXCM FIX. | 2014-02-26 13:41:54 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:41:54 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:41:59 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:41:59 The network socket is connected. | 2014-02-26 13:41:59 FXCM FIX: Sending the Logon message. | 2014-02-26 13:42:00 Socket closed. No error. | 2014-02-26 13:42:00 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:42:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:42:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:42:00 Disconnected from FXCM FIX. | 2014-02-26 13:42:00 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:42:00 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:42:05 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:42:05 The network socket is connected. | 2014-02-26 13:42:05 FXCM FIX: Sending the Logon message. | 2014-02-26 13:42:06 Socket closed. No error. | 2014-02-26 13:42:06 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:42:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:42:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:42:06 Disconnected from FXCM FIX. | 2014-02-26 13:42:06 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:42:06 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:42:11 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:42:11 The network socket is connected. | 2014-02-26 13:42:11 FXCM FIX: Sending the Logon message. | 2014-02-26 13:42:12 Socket closed. No error. | 2014-02-26 13:42:12 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:42:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:42:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:42:12 Disconnected from FXCM FIX. | 2014-02-26 13:42:12 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:42:12 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:42:17 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:42:17 The network socket is connected. | 2014-02-26 13:42:18 FXCM FIX: Sending the Logon message. | 2014-02-26 13:42:18 Socket closed. No error. | 2014-02-26 13:42:21 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:42:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:42:21 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:42:21 Disconnected from FXCM FIX. | 2014-02-26 13:42:21 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:42:21 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:42:26 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:42:26 The network socket is connected. | 2014-02-26 13:42:27 FXCM FIX: Sending the Logon message. | 2014-02-26 13:42:27 Socket closed. No error. | 2014-02-26 13:42:27 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:42:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:42:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:42:27 Disconnected from FXCM FIX. | 2014-02-26 13:42:27 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:42:27 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:42:32 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:42:32 The network socket is connected. | 2014-02-26 13:42:33 FXCM FIX: Sending the Logon message. | 2014-02-26 13:42:33 Socket closed. No error. | 2014-02-26 13:42:33 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:42:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:42:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:42:33 Disconnected from FXCM FIX. | 2014-02-26 13:42:33 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:42:33 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:42:38 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:42:38 The network socket is connected. | 2014-02-26 13:42:42 FXCM FIX: Sending the Logon message. | 2014-02-26 13:42:42 Socket closed. No error. | 2014-02-26 13:42:42 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:42:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:42:42 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:42:42 Disconnected from FXCM FIX. | 2014-02-26 13:42:42 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:42:42 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:42:47 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:42:47 The network socket is connected. | 2014-02-26 13:42:48 FXCM FIX: Sending the Logon message. | 2014-02-26 13:42:48 Socket closed. No error. | 2014-02-26 13:42:51 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:42:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:42:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:42:51 Disconnected from FXCM FIX. | 2014-02-26 13:42:51 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:42:51 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:42:56 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:42:56 The network socket is connected. | 2014-02-26 13:42:57 FXCM FIX: Sending the Logon message. | 2014-02-26 13:42:57 Socket closed. No error. | 2014-02-26 13:42:58 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:42:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:42:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:42:58 Disconnected from FXCM FIX. | 2014-02-26 13:42:58 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:42:58 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:43:03 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:43:03 The network socket is connected. | 2014-02-26 13:43:03 FXCM FIX: Sending the Logon message. | 2014-02-26 13:43:03 Socket closed. No error. | 2014-02-26 13:43:04 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:43:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:43:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:43:04 Disconnected from FXCM FIX. | 2014-02-26 13:43:04 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:43:04 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:43:09 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:43:09 The network socket is connected. | 2014-02-26 13:43:09 FXCM FIX: Sending the Logon message. | 2014-02-26 13:43:10 Socket closed. No error. | 2014-02-26 13:43:10 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:43:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:43:10 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:43:10 Disconnected from FXCM FIX. | 2014-02-26 13:43:10 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:43:10 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:43:15 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:43:15 The network socket is connected. | 2014-02-26 13:43:24 FXCM FIX: Sending the Logon message. | 2014-02-26 13:43:25 Socket closed. No error. | 2014-02-26 13:43:25 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:43:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:43:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:43:25 Disconnected from FXCM FIX. | 2014-02-26 13:43:25 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:43:25 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:43:30 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:43:30 The network socket is connected. | 2014-02-26 13:43:30 FXCM FIX: Sending the Logon message. | 2014-02-26 13:43:31 Socket closed. No error. | 2014-02-26 13:43:31 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:43:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:43:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:43:31 Disconnected from FXCM FIX. | 2014-02-26 13:43:31 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:43:31 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:43:36 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:43:36 The network socket is connected. | 2014-02-26 13:43:36 FXCM FIX: Sending the Logon message. | 2014-02-26 13:43:37 Socket closed. No error. | 2014-02-26 13:43:37 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:43:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:43:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:43:37 Disconnected from FXCM FIX. | 2014-02-26 13:43:37 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:43:37 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:43:42 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:43:42 The network socket is connected. | 2014-02-26 13:43:43 FXCM FIX: Sending the Logon message. | 2014-02-26 13:43:43 Socket closed. No error. | 2014-02-26 13:43:43 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:43:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:43:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:43:43 Disconnected from FXCM FIX. | 2014-02-26 13:43:43 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:43:43 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:43:48 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:43:48 The network socket is connected. | 2014-02-26 13:43:49 FXCM FIX: Sending the Logon message. | 2014-02-26 13:43:49 Socket closed. No error. | 2014-02-26 13:43:49 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:43:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:43:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:43:49 Disconnected from FXCM FIX. | 2014-02-26 13:43:49 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:43:49 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:43:54 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:43:54 The network socket is connected. | 2014-02-26 13:43:55 FXCM FIX: Sending the Logon message. | 2014-02-26 13:43:55 Socket closed. No error. | 2014-02-26 13:43:56 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:43:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:43:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:43:56 Disconnected from FXCM FIX. | 2014-02-26 13:43:56 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:43:56 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:44:01 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:44:01 The network socket is connected. | 2014-02-26 13:44:01 FXCM FIX: Sending the Logon message. | 2014-02-26 13:44:01 Socket closed. No error. | 2014-02-26 13:44:02 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:44:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:44:02 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:44:02 Disconnected from FXCM FIX. | 2014-02-26 13:44:02 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:44:02 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:44:07 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:44:07 The network socket is connected. | 2014-02-26 13:44:07 FXCM FIX: Sending the Logon message. | 2014-02-26 13:44:07 Socket closed. No error. | 2014-02-26 13:44:08 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:44:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:44:08 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:44:08 Disconnected from FXCM FIX. | 2014-02-26 13:44:08 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:44:08 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:44:13 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:44:13 The network socket is connected. | 2014-02-26 13:44:13 FXCM FIX: Sending the Logon message. | 2014-02-26 13:44:13 Socket closed. No error. | 2014-02-26 13:44:14 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:44:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:44:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:44:14 Disconnected from FXCM FIX. | 2014-02-26 13:44:14 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:44:14 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:44:19 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:44:19 The network socket is connected. | 2014-02-26 13:44:19 FXCM FIX: Sending the Logon message. | 2014-02-26 13:44:20 Socket closed. No error. | 2014-02-26 13:44:20 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:44:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:44:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:44:20 Disconnected from FXCM FIX. | 2014-02-26 13:44:20 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:44:20 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:44:25 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:44:25 The network socket is connected. | 2014-02-26 13:44:26 FXCM FIX: Sending the Logon message. | 2014-02-26 13:44:26 Socket closed. No error. | 2014-02-26 13:44:26 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:44:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:44:26 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:44:26 Disconnected from FXCM FIX. | 2014-02-26 13:44:26 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:44:26 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:44:31 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:44:31 The network socket is connected. | 2014-02-26 13:44:32 FXCM FIX: Sending the Logon message. | 2014-02-26 13:44:32 Socket closed. No error. | 2014-02-26 13:44:33 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:44:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:44:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:44:33 Disconnected from FXCM FIX. | 2014-02-26 13:44:33 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:44:33 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:44:38 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:44:38 The network socket is connected. | 2014-02-26 13:44:38 FXCM FIX: Sending the Logon message. | 2014-02-26 13:44:38 Socket closed. No error. | 2014-02-26 13:44:39 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:44:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:44:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:44:39 Disconnected from FXCM FIX. | 2014-02-26 13:44:39 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:44:39 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:44:44 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:44:44 The network socket is connected. | 2014-02-26 13:44:44 FXCM FIX: Sending the Logon message. | 2014-02-26 13:44:45 Socket closed. No error. | 2014-02-26 13:44:45 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:44:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:44:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:44:45 Disconnected from FXCM FIX. | 2014-02-26 13:44:45 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:44:45 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:44:50 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:44:50 The network socket is connected. | 2014-02-26 13:44:51 FXCM FIX: Sending the Logon message. | 2014-02-26 13:44:51 Socket closed. No error. | 2014-02-26 13:45:12 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:45:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:45:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:45:12 Disconnected from FXCM FIX. | 2014-02-26 13:45:12 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:45:12 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:45:17 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:45:17 The network socket is connected. | 2014-02-26 13:45:18 FXCM FIX: Sending the Logon message. | 2014-02-26 13:45:18 Socket closed. No error. | 2014-02-26 13:45:19 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:45:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:45:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:45:19 Disconnected from FXCM FIX. | 2014-02-26 13:45:19 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:45:19 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:45:24 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:45:24 The network socket is connected. | 2014-02-26 13:45:24 FXCM FIX: Sending the Logon message. | 2014-02-26 13:45:24 Socket closed. No error. | 2014-02-26 13:45:25 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:45:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:45:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:45:25 Disconnected from FXCM FIX. | 2014-02-26 13:45:25 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:45:25 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:45:30 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:45:30 The network socket is connected. | 2014-02-26 13:45:30 FXCM FIX: Sending the Logon message. | 2014-02-26 13:45:30 Connection timed out. Will disconnect and retry. | 2014-02-26 13:46:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:46:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:46:30 FXCM FIX: Sending a Logout message. | 2014-02-26 13:46:30 Disconnected from FXCM FIX. | 2014-02-26 13:46:30 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:46:30 FXCM FIX: Waiting for Logout response timed out. Closing the socket now. | 2014-02-26 13:46:34 FXCM FIX: Socket closed without completing the logout sequence. | 2014-02-26 13:46:34 Current selected Data/Trading service: FXCM FIX Trading | 2014-02-26 13:48:30 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:48:36 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:48:36 The network socket is connected. | 2014-02-26 13:48:36 FXCM FIX: Sending the Logon message. | 2014-02-26 13:48:37 Socket closed. No error. | 2014-02-26 13:48:37 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:48:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:48:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:48:37 Disconnected from FXCM FIX. | 2014-02-26 13:48:37 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:48:37 The above has been sent to support. | 2014-02-26 13:49:37 Sending of the message log was completed. Please read the response that was received. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2014-02-26 13:49:41 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:51:37 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:51:37 The network socket is connected. | 2014-02-26 13:51:38 FXCM FIX: Sending the Logon message. | 2014-02-26 13:51:38 Socket closed. No error. | 2014-02-26 13:51:38 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:51:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:51:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:51:38 Disconnected from FXCM FIX. | 2014-02-26 13:51:38 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:51:38 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:51:53 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:51:53 The network socket is connected. | 2014-02-26 13:51:53 FXCM FIX: Sending the Logon message. | 2014-02-26 13:51:53 Socket closed. No error. | 2014-02-26 13:51:54 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:51:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:51:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:51:54 Disconnected from FXCM FIX. | 2014-02-26 13:51:54 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:51:54 Current selected Data/Trading service: FXCM FIX Trading | 2014-02-26 13:54:53 Connecting to FXCM FIX at address: fixreal.fxcorporate.com:8024 | 2014-02-26 13:54:54 Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2014-02-26 13:54:54 The network socket is connected. | 2014-02-26 13:54:54 FXCM FIX: Sending the Logon message. | 2014-02-26 13:54:54 Socket closed. No error. | 2014-02-26 13:54:55 FXCM FIX: Socket connection was closed without any logout messages sent or received. | 2014-02-26 13:54:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-02-26 13:54:55 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-02-26 13:54:55 Disconnected from FXCM FIX. | 2014-02-26 13:54:55 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-02-26 13:54:55 |
[2014-02-26 16:21:47] |
Are you connected to the same FXCM username from Sierra Chart or another program, at the same time you are trying to connect? If so, this is most likely the reason why the connection is not working. Only one connection is allowed at a time. Although you should not have a problem using the FXCM Trading Station at the same time. The first thing you need to do is try disconnecting all of the programs using the same FXCM username and see if you can connect. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-26 19:57:06] |
nope, not connected to same FXCM username as sierra chart on the other program. Tried closing down the other program completely, but still cant connect on sierra. Tried also leaving password and account details blank but still cant connect. I use sierra in the office and also at home, the office connection seemed fine earlier today, Does Sierra track IP addresses? Both are not logged in at the same time though. |
[2014-02-26 20:19:26] |
aha! Data does come in, when i open a new chart data comes in. But then doesnt update. However, i still get yellow 'waiting to reconnect' window on top right. :-( |
[2014-02-26 20:27:18] |
HD Request # 3 - Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2014-02-26 20:26:28 HD Request # 3 - Download start Date-Time: 2014-02-21 21:34:50.0 | 2014-02-26 20:26:28 HD Request # 3 - Using server: ds4.sierracharts.com port 10149 | 2014-02-26 20:26:28 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-02-26 20:26:29 The network socket is connected. | 2014-02-26 20:26:29 HD Request # 3 - Sending historical data logon request message. | 2014-02-26 20:26:29 HD Request # 3 - Requesting Intraday data. Max. days to return: 100. Start Date-Time: 2014-02-21. Record interval: 1 | 2014-02-26 20:26:30 HD Request # 3 - Decompressing data. | 2014-02-26 20:26:30 HD Request # 3 - Receiving Intraday data for EURUSD starting at 2014-02-21 21:34:50 | 2014-02-26 20:26:30 HD Request # 3 - Timestamp of first Intraday data file record written: 2014-02-21 21:34:50 | 2014-02-26 20:26:30 The network socket for historical data has been closed. | 2014-02-26 20:26:43 HD Request # 3 - Historical data for EURUSD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-02-26 20:26:43 HD Request # 3 - Received 82857 records from 2014-02-21 21:34:50 to 2014-02-26 20:26:30 (5.0 days) and wrote 82857 records for EURUSD | 2014-02-26 20:26:43 HD Request # 3 - Intraday download COMPLETE for EURUSD | 2014-02-26 20:26:43 |
[2014-02-26 20:30:45] |
heres a screenshot of my data/trade service settings. http://my.jetscreenshot.com/22895/20140226-gwou-65kb As i mentioned before i also have tried with password and account details entered but still get connection error |
[2014-02-26 20:36:02] |
Did you specify all of the Connection Details? All of those boxes need to be filled in. API@FXCM.com can help you with the specific details to enter if you are not sure of some of them. Based upon the immediate disconnection by the server it is probably one of the first three settings under the Server which are not correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-26 20:36:56
[2014-02-26 21:01:55] |
so.. why does it connect on my home computer? i dont have all those boxes filled. I have emailed api@fxcm.com and they will reply within 2 days which is no good for me. |
[2014-02-26 21:10:33] |
We cannot answer that question. We do not control the FXCM server and do not know exactly what the settings are.
