Date/Time: Mon, 28 Sep 2026 21:50:15 +0000
order rejected insufficient permissions
View Count: 1144
[2021-02-18 15:29:24]
User906481 - Posts: 2
Hi when I try to trade I'm receiving the message "order rejected insufficient permissions"
[2021-02-18 16:23:51]
John - SC Support - Posts: 48044
TT is still working on their issue therefore AMP has stopped any trading to take place through TT. You will need to talk to AMP about this for further information.
[2021-02-18 19:18:37]
User419951 - Posts: 14
Hi John thank you,I've had an e-mail from Amp suggesting that it might be an idea to switch over to CQG would that incur more charges?
Also I'm still only getting delayed trading on US 10yr treasury note and earlier whilst trying to trade it kept switching me to simulation mode?
Thanks for your help
Chris.
[2021-02-18 20:00:06]
Switching to CQG would not incur any additional charges on the Sierra Chart side. There may be some differences in the commissions that are charged, but you would need to check that with AMP.
Are you getting delayed data for the US 10 Year Treasury Note Futures (ZN)? and not for other CME Products?
Also, we see no reason for the system to switch you to simulation mode when trying to place a trade. But let us know about the data first and then we will work through any further issues.
[2021-02-18 20:20:20]
Yes delayed data only on the US 10yr treasury note future's (ZN) the rest of the CME products are ok.
Not sure if it's caused any issues but I have changed to full CME products but without the market depth which I didn't really need.
[2021-02-18 20:47:37]
We need to see your Message Log following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
[2021-02-19 08:12:27]
Software version: 2231 64-bit | 2021-02-19 03:06:54.736
Primary Thread ID: 5048 | 2021-02-19 03:06:54.736
Usage end date: 2021-03-05 | 2021-02-19 03:06:54.736
Enabled for: Advanced Features 2. | 2021-02-19 03:06:54.736
Enabled for: Sierra Chart Historical Data Service. | 2021-02-19 03:06:54.736
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-02-19 03:06:54.736
Enabled for: Delayed Denali Exchange Data Feed. | 2021-02-19 03:06:54.736
Enabled for exchange2: CME | 2021-02-19 03:06:54.736
Enabled for exchange2: NYMEX | 2021-02-19 03:06:54.736
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-02-19 03:06:54.736
Current selected Data/Trading service: SC Futures Order Routing/Data | 2021-02-19 03:06:54.736
Custom symbol settings values: enabled | 2021-02-19 03:06:54.736
Chart Update Interval: 500 | 2021-02-19 03:06:54.736
Intraday Data Storage Time Unit: 2 | 2021-02-19 03:06:54.736
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-02-19 03:06:54.736
2021-02-19 08:06:54 Local computer time in UTC | 2021-02-19 03:06:54.736
2021-02-19 03:06:54 Local computer time in SC Time Zone | 2021-02-19 03:06:54.736
2021-02-19 07:41:41 Server time in UTC | 2021-02-19 03:06:54.736
Local computer UTC time and Server UTC time difference: 3 seconds. | 2021-02-19 03:06:54.736
Program path: C:\SierraChart\ | 2021-02-19 03:06:54.736
Data Files path: C:\SierraChart\Data\ | 2021-02-19 03:06:54.736
OS Version Number: 10.0 | 2021-02-19 03:06:54.737
Locale Setting: C | 2021-02-19 03:06:54.737
DLLs: UserContributedStudies_64.dll | 2021-02-19 03:06:54.737
Allowed protected custom studies: | 2021-02-19 03:06:54.737
The symbol of the chart is ZNH21
[2021-02-19 15:43:53]
We think the issue you are seeing is related to using both old and new symbology. Please open your Chartbook(s) and select Edit >> Translate Symbols to Current Service.
Let us know if that resolves your issue for ZN.
[2021-02-19 18:07:18]
Hi yes that's done the trick,thank you....I've just found trades that I've not taken on my chart is that an AMP or CQG error?
[2021-02-20 05:17:43]
From our perspective we do not know. You can look at the Trade Activity Log and ask your broker about any order fills that you see which do not make sense:
Trade Activity Log: Viewing Historical Trade Activity
Date Time Of Last Edit: 2021-02-20 05:18:17
[2021-09-08 08:26:40]
User973068 - Posts: 1
when I try to trade the FDXM on EUREX I'm receiving the message "order rejected insufficient permissions: route does not exist.
[2021-09-08 11:13:35]
You need to contact your broker and ask them about this.
