Date/Time: Sun, 23 Feb 2025 18:38:01 +0000
Datenfeed
View Count: 914
[2021-02-16 15:09:49]
Timo Costa - Posts: 28
Hallo ich habe heute Sierra chart neue version runtergeladen und meine Aktien datenfeed funktioniert nicht mehr.
ich habe für den Monat Februar den Daten Feed bezahlt und es müsste alles funktionieren .
Können Sie mir helfen .
Vielen dank
[2021-02-16 17:43:15]
John - SC Support - Posts: 38116
From Google Translate:
Hello I downloaded the new version of Sierra Chart today and my share data feed no longer works.
I paid the data feed for the month of February and everything should work.
Can you help me .
Many Thanks
We do not see any reason for you to be having issues with the data. If you are still having a problem then tell us exactly the problem you are having (is data not coming in at all, is it delayed, is it something else) and get us your Message Log by following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2021-02-16 18:54:36]
Ich habe das Problem gefunden. Wenn ich mich auf den anderen Computer im 2 System anmelde dann habe ich im 1 System kein Daten Feed . Ist das korrekt so ?
[2021-02-16 19:34:16]
I found the problem. When I log on to the other computer in the 2 system then I have no data feed in the 1 system. Is that correct?
What you are seeing makes sense. You can only be connected to the Data Feed from one computer at a time.
[2021-02-17 08:06:59]
Es ist aber so das ich auf den 2 Systeme nicht diesen Daten Feed brauche sondern ein anderen habe.
Beispiel : 1 Systeme SC Daten Feed
2 Systeme cqg Daten Feed
Dann dürfte das kein Problem sein oder ?
[2021-02-17 15:21:20]
But it is so that I do not need this data feed on the 2 systems but have another one.
Example: 1 systems SC data feed
2 systems cqg data feed
Then that shouldn't be a problem, right?
All we can speak to is our data. The Sierra Chart Exchange Data Feed only allows for 1 computer to be connected at a time.
You would need to ask CQG, or your broker, about the CQG data.
[2021-02-19 19:54:18]
Okay jetzt weiß ich bescheid . Danke
[2021-02-22 14:38:10]
Data from CQG is limited to one connection at a time.
