Date/Time: Fri, 18 Sep 2026 04:12:52 +0000
Error downloading historical Intraday data for FGBLH21-EUREX
View Count: 883
[2021-02-15 17:36:32]
Nicogou21 - Posts: 12
Greetings,
When connecting with my Denali Sierra Feed this morning, I received this error message which unbales me to download the Eurex Data.
Could you tell me why?
Because it seems that I am up to date with my payments.
Best Regards,
Nicolas
Date Time Of Last Edit: 2021-02-15 19:18:39
imageDownload failed 15.02.21.PNG / V - Attached On 2021-02-15 17:36:06 UTC - Size: 197.63 KB - 343 views
[2021-02-15 18:15:34]
John - SC Support - Posts: 47930
Please update to the current release.
[2021-02-15 18:24:12]
Could you elaborate on how to do that please?
[2021-02-15 18:56:54]
User485386 - Posts: 1
Same here
I was getting the same error message as the above Gentleman, updated to the latest version, still getting the error message. I updated to the Pre-Release version, now the error message has disappeared but I was still not getting historical intraday DAX data, all other futures contracts I follow seem to be fine, just the DAX had an issue.
If it helps anyone I opened a Historical chart for the DAX, which seemed to work, then I changed the Volume chart I originally had open to a 1 minute chart (Data came through), I could then change back to a volume chart.
[2021-02-15 19:15:46]
To update to the current version of Sierra Chart follow the instructions here:
If you still have an issue we need you to follow the instructions here:
Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download".
After about a minute provide a copy of the Message Log following these instructions:
This is not a solution at all:
