Date/Time: Tue, 04 Nov 2025 10:39:30 +0000
VIX Index
View Count: 1637
|   [2021-02-11 18:22:11]     |
| User487595 - Posts: 14 |
                Is it possible to add the VIX index via CFD or something? So you don't have to activate the exchange, other platforms I've used have vix cfd  |
|   [2021-02-12 22:16:29]     |
                We will be offering the volatility index futures through the Denali  Exchange Data Feed within the next three months. There will be a small exchange fee for that though. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-12 22:16:38
|   [2021-07-09 07:56:19]     |
| User893396 - Posts: 40 |
                Hello, Is it done? Is there any way to have the VIX Index or Future? What's the fee and what's the procedure? Thanks  |
|   [2021-07-09 08:19:54]     |
                Yes this is now available.  It is the volatility index futures. You can set this up from here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliCFE Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-09 08:20:05
