Date/Time: Tue, 04 Nov 2025 11:00:17 +0000
Footprint Replay issue
View Count: 843
[2021-02-09 15:41:14]
User709035 - Posts: 2
I am practicing with the Replay function and I noticed an issue. In particular, my chartbook is made up of different charts among which a footprint (see capture 1).
When I start the Replay function, if I start it from mid December on, the footprint chart works regularly. However, if I start it a bit earlier like in November, it does not work (see capture 2). I already increased the number of days to load (see capture 3) but it does not work.
How can I fix it?
Thank you
imageCapture1.PNG / V - Attached On 2021-02-09 15:40:44 UTC - Size: 98.59 KB - 419 views
imageCapture2.PNG / V - Attached On 2021-02-09 15:40:50 UTC - Size: 51.12 KB - 282 views
imageCapture3.PNG / V - Attached On 2021-02-09 15:40:55 UTC - Size: 162.32 KB - 258 views
[2021-02-09 17:49:46]
John - SC Support - Posts: 42737
What does the data look like back in November without running the replay?
