Date/Time: Tue, 04 Nov 2025 16:32:20 +0000
SC buildsystem with other folder
View Count: 1004
[2021-02-04 20:11:17]
User30743 - Posts: 366
Hi, I am trying to build my custom studies using your build system, but how do I actually navigate to the folders where my code is? Whenever I click files the ACS_Source directory opens and there is no way to navigate anywhere else. Do I need to move my code files there? If so, why is it that way? I want to keep my files in a nicely organized way, and moving them all into one folder is not the best option...
I can't even see any subfolders I created there in ACS_Source https://prnt.sc/yb78fl . Again, why is it that way?
Date Time Of Last Edit: 2021-02-04 20:13:47
[2021-02-05 12:27:16]
Yes. This is just how it is.
[2021-02-05 17:33:33]
ok. and the WHY part? or, do u plan to make it work for other folders/subfolders also?
Date Time Of Last Edit: 2021-02-05 17:33:47
[2021-06-18 18:18:12]
any updates on this? it cannot be that difficult to be able to make a navigation for a local filesystem..
Date Time Of Last Edit: 2021-06-18 18:18:28
