Date/Time: Sat, 03 Oct 2026 01:07:22 +0000
FRANK733
View Count: 997
| [2021-02-04 17:03:29] |
| User517307 - Posts: 3 |
Hi is my data live or delayed? Need the live data
| [2021-02-04 17:54:30] |
| John - SC Support - Posts: 48095 |
You are currently receiving the Delayed Streaming Data for the CME Group. This is because the Denali Exchange Data Feed for your account did not automatically renew on February 1, 2021 since you did not have enough funds in your account to pay for it. If you want to reactivate the Denali Exchange Data Feed, then you will first need to add funds to your account, which can be done here: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit Then you can reactivate the services that were turned off by going to this page: https://www.sierrachart.com/UserControlPanel.php?page=RecurringServices For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-02-04 21:47:41] |
Hi thx for the help. I don't need the Dinali feed if your normal sierra feed includes live data for the 36.00 monthly fee. But if I still have to,I will pay the 3.25 extra for it, no problem. Thx again Rod
| [2021-02-04 22:00:14] |
In order to get the Real-Time data for the CME Group you would need to pay for it. This includes the Denali Exchange Data Feed fee and the exchange fee(s). These fees are above the pricing for the Sierra Chart software. You can also pay for the Denali Exchange Data Feed fee by using packages 10, 11, or 12. which have the Denali Feed fee built in. But you will still need to pay the exchange fee through the Denali Exchange Data Feed. Either way you set it up it costs the same. The information for the Denali Exchange Data Feed, including pricing, can be found here: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-02-04 23:27:12] |
Ok thx again, will get the exchange feed. Thx for the quick replies! Rod
| [2021-02-09 01:18:19] |
We see you have activated a nonprofessional CME exchange fee. Please be aware of the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
