Date/Time: Fri, 11 Sep 2026 19:43:43 +0000
chart settings problem
View Count: 1514
[2014-02-24 22:35:25]
mayerrs - Posts: 70
hi, i have problem with settings of the chart for ZC, ZS, ZW. i have price display format 0.0001 and tick size 0.0025. price is 4.5875 in ZC. i would like to see price 458.75 so i made price display format 0.01 and tick size 0.25 and nothing changed. am i doing something wrong?
and other thing. if i have ZC intraday chart i can see the price 4.5875 but when i have historical chart i can see price 458.75.
[2014-02-25 00:17:22]
You also have to adjust the Real-time and Historical Price Multipliers in Chart >> Chart Settings >> Advanced Settings 2.
However, if you are using Interactive Brokers, we have verified that the default settings are as you want them and you do not have to change the settings from defaults. So which indicates you have the incorrect settings to begin with.
Update the Symbol Settings as explained here:
https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings
And be sure to apply them to existing charts:
https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateChartSettingsSteps
Date Time Of Last Edit: 2014-02-25 00:17:49
[2014-02-25 13:54:50]
mayerrs - Posts: 70
you are right i use IB but my brother does use infinity futures and when i tried to log into supord board from his sierra it was not working. that is why i used my account. in his sierra this is as i wrote.
[2014-02-25 17:05:41]
Do you still need help?
[2014-02-25 19:32:18]
mayerrs - Posts: 70
i made it myself. thanks for usefull links - they helped me.
