Date/Time: Sat, 22 Feb 2025 18:10:18 +0000
Suggestion for Improvement - Studies Window
View Count: 412
[2021-02-03 08:44:13] |
User186889 - Posts: 54 |
Hi Sierra, I think Sierra is a great tool, but does have its quirks that could, I believe, benefit others by simple changes. My suggestion is a change of format of the Studies Window to include: 1. A deeper 'Studies To Graph - Alerts' window so I can see the code I am writing without having to peer at it through a letter box 2. The facility to add remarks after my code - for example: -=(id1.sg1>50)// or Rem "This setting was too sensitive on 45" 3. Add a separate window for 'My Notes'. I write many pieces of code but I do not want to have to copy and paste to a WORD file etc each time I have added a PNG file as a working example Thanks - Mark B |
![]() Attachment Deleted. |
[2021-02-04 09:25:11] |
Ok we will make a note of these things. Regarding comments, the best performance would be if the comments are left to the notes section.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-04 09:26:41
