Date/Time: Sun, 23 Feb 2025 02:40:33 +0000
I would like to submit the trades to the Rithmic account
View Count: 662
[2021-02-02 17:13:15]
Ferenc Reischig - Posts: 11
Thanks for your help, I see you have managed to set it up.
2. I would like to submit the trades to the Rithmic account
- Rithmic Trading / Paper Trading Server
- user: fXXXXXXXX
What steps should I take?
Date Time Of Last Edit: 2021-02-02 17:13:39
[2021-02-03 10:27:22]
I've set this up:
Global Settings >> Data/Trade Service Settings.
Enable the Allow Support for Sierra Chart Data Feeds option.
How do I send trades to the Rithmic account?
(Rithmic Trading / Paper Trading Server)
[2021-02-03 10:59:23]
You need to disable Trade Simulation Mode as explained here:
Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes
Date Time Of Last Edit: 2021-02-03 10:59:28
[2021-02-03 16:36:56]
Simulation mode is off.
In the trading panel, the Trade account list box can only be selected as "unset"
imageSC data trade services settings.png / V - Attached On 2021-02-03 16:33:54 UTC - Size: 25.48 KB - 191 views
imageTrade window.png / V - Attached On 2021-02-03 16:33:59 UTC - Size: 23.07 KB - 222 views
[2021-02-03 18:13:12]
John - SC Support - Posts: 38116
Your Trade Window is showing Unset since you do not have a selected Trading Service in Data/Trade Service Settings >> Service.
In order to tell you what to do, we need to know if you are using Rithmic or the Sierra Chart Order Routing. We see you are setup with the Sierra Chart Order Routing, but you are referencing Rithmic in your questions.
Once we know which service you are using, we can point you to the proper setup instructions.
[2021-02-04 07:50:02]
Here's what I want to set up:
1. SC Data Feed draws the chart
Rithmic Trading / Paper Trading Server (Earn2Trade)
[2021-02-04 14:52:30]
You would need to set the File >> Data/Trade Service Settings >> Current Selected Service to Rithmic Trading and setup your connections as appropriate. You may also need the updated Bridge files which can be found here:
Rithmic Bridge Files
Then you would go through the setup in the Integration with Trading Service section here:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
Note that we are no longer giving technical support for Rithmic, therefore what we have given you above is all we can give you in terms of supporting Rithmic.
[2021-02-05 17:05:24]
Thank you for your help,
everything works fine
