Date/Time: Thu, 10 Sep 2026 05:00:43 +0000
Trading Position Average Price
View Count: 940
| [2021-02-01 16:00:01] |
| User87521 - Posts: 116 |
See attached image file. I am running in Sim mode. Trade Position Average Price does not seem to work in real time. In backtests it works every time. If I close this chartbook and re-open the TPAP will calculate correctly and stay until parameters call for a change. I have other charbooks which utilize TPAP and they seem to work fine real time and backtest. I cannot see a reason why this does not work when Sierra clearly recognizes that there is an actual trade position. Thanks. http://www.sierrachart.com/image.php?Image=1612195077185.png |
| [2021-02-01 19:54:02] |
Is Trade >> Trade Simulation Mode On enabled? Check this setting: Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-02-01 20:07:28] |
That setting is blank. No values entered.
| [2021-02-02 15:13:58] |
However, if you have a Trade Position which spans a long time, then it may be necessary to set this to a date earlier than the earliest date loaded in the chart.
I decided to try this, even though my trades do not span much time in this chartbook. A trade was taken this morning and no Trade Position Average Price was registered. When I set the date to Jan 1 the TPAP immediately updated correctly. It just finished the trade and sold for a profit using the TPAP as part of the close trade criteria. It seems that this has solved the problem although I'm not sure why yet at this point. I can see where a longer timeframe trade or multiple trade positions would make this more important, but I was not in any other positions and the trade size was 1. Anyway, from now one, if I use TPAP I will also set this date back at least a month and see if that works better. Thanks. |
| [2021-02-04 05:26:52] |
Is it normal for this setting to disappear? I can set it and it seems to stick until I run a back-test. When I run the back-test it disappears in every chartbook.
