Date/Time: Sat, 22 Feb 2025 17:28:13 +0000
sierra chart - not connected
View Count: 666
[2021-02-01 15:45:31]
User583120 - Posts: 5
hi team
when I log on to my sierra accout a ihave on the top left side on the screen on the red information NOT CONNECTED
information I received is:
connect to the data feed
curent service package does nor support this function
help-> account control panel' to change your package
I try to do that
byt after log in to my panel I found information
Available Services
Choose Service Package and Time Period for Usage Time, or "Disabled":
Not available for your account type, as it is associated with a reseller. For your account, Service Package activation and deactivation is controlled by a reseller for your account. Your current Service Package is 3 with an ending date of 2021-02-13.
what I should do to have sierra accout connected?
my account number
BR
Anna
Date Time Of Last Edit: 2021-02-01 15:50:44
[2021-02-01 15:52:29]
Perform this procedure here:
Sierra Chart - Software Login Instructions: Forced Login
Let us know if you can then connect.
Date Time Of Last Edit: 2021-02-01 15:52:40
[2021-02-01 15:59:09]
hi team,
still not working
not connected
attached screen
please check why is not working
thanks for your help
imageerrorr.PNG / V - Attached On 2021-02-01 15:57:58 UTC - Size: 270.23 KB - 187 views
[2021-02-01 19:40:40]
Ok we see you are trying to connect to SC Data-All Services. That is not supported on your account with AMP. You would need to connect either to CQG or the Sierra Chart Order Routing Service. Instructions for each:
Sierra Chart / Trading Technologies Futures Order Routing Service
CQG Trading Platform Service
Date Time Of Last Edit: 2021-02-02 11:07:18
[2021-02-02 09:11:38]
hi team,
it still the same
I did what waas in manual but it did'n help
nothing change
please check what I cannot connect sierra?
BR
Anna
[2021-02-02 13:01:23]
hi Team
CQC connection i woerking
now is green ;-)
you can close ticket
have a nice day
BR
Anna
