Date/Time: Mon, 25 Nov 2024 16:24:11 +0000
[User Discussion] - range bars on 6E
View Count: 1629
[2014-02-24 10:04:17] |
User60591 - Posts: 39 |
Hi, I have a problem with range bars. they do not draw as they should. I don't know, maybe it's a data feed or something else. pls look at it. thank you s Date Time Of Last Edit: 2014-02-24 11:09:30
4RB_24022014.jpg / V - Attached On 2014-02-24 10:01:48 UTC - Size: 98.62 KB - 341 views |
[2014-02-24 10:29:52] |
This is because people want these bars to be manipulated and not represent the actual true prices. For what reason, we do not know. The closing price you see for a bar is not necessarily accurate. Please refer to the documentation here for a complete description: https://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#RangeBarStandard And you also want to make sure you have a tick by tick data configuration: https://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php We cannot offer further help. You may want to use Range Per Bar-True to get a true representation. Range bars are one of the most manipulated bar types. Why users want them manipulated, makes no sense. Generally the reason is they see how this is done with other programs and then it gets established and they think it has to be this way otherwise the bars are wrong. This is why we created Range Per Bar-True. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-24 10:34:15
[2014-02-24 11:14:29] |
Thank you for the answer and suggestion. Can you pls be more specific, namely I wanna understand how does it happens and why do I see the bars like that because I build the spreadsheet sistem based on them. So in my case I don't understand this concept of manipulation on a 4 tick range bar. When I run the simulation i don't get the signal on those bars with equal high and last price (if there should be a signal) and they are drawn as they should be drawn. On "live" i have a problem with them. I will figure something out. I just want to expend my knowledge becuse I didn't hear of it before, can you pls give Us an brief example or explanation how the manipulation is done. thank you Date Time Of Last Edit: 2014-02-24 11:14:39
