Date/Time: Sat, 22 Feb 2025 09:04:36 +0000
Data trade service settings
View Count: 761
[2021-01-29 14:31:13] |
User419951 - Posts: 14 |
Hi in the data trade service settings window I am getting a different type of window pop up?
[2021-01-29 15:21:15] |
John - SC Support - Posts: 38116 |
These are new dialog windows that we are developing and rolling out as we get them ready. Refer to the information here: Getting Started, Opening Charts and Basic Trading: Working with Sierra Chart Settings Windows For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-29 20:05:30] |
Hi I'm still only receiving delayed data feed and I'm connected to the data feed...can anyone help please!!
[2021-01-29 20:23:11] |
Everything looks good on our end, and you have everything setup properly. The first thing to check is that you have the option for File >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds is set to Yes. Refer to the information here: Data/Trade Service Settings: Allow Support for Sierra Chart Data Feeds (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings) Another possibility is that you have only signed up for Real-Time data from the CME exchange. If you are looking at a symbol that trades on a different exchange, then those will give you the delayed data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-29 20:32:40] |
Hi John, checked that and is set to 'yes', so how do I obtain the E-Mini S&P 500,because I can't seem to find it to add?
[2021-01-29 20:56:16] |
Go to File >> Find Symbol, then open the section for FUTURES - CME. It will be in there. Refer to the information here: Getting Started, Opening Charts and Basic Trading: Open A Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-11 05:41:08
