Date/Time: Tue, 04 Nov 2025 12:43:37 +0000
Tengo una cuenta AMP
View Count: 769
|   [2021-01-22 20:43:01]     |
| Yxel Morillo - Posts: 5 |
                Buen dia, tengo una cuenta con AMP futures, que quisiera conectar con Sierra Chart para operar el Micro S&P500 en real. Me pueden ayudar a conectar mi cuenta AMP Futures con Sierra Chart? Gracias!  |
|   [2021-01-22 22:58:47]     |
| John - SC Support - Posts: 42737 |
                From Google Translate: Good morning, I have an account with AMP futures, which I would like to connect with Sierra Chart to operate the Micro S & P500 in real.
Can you help me connect my AMP Futures account with Sierra Chart? Thank you! What Trading Service are you using with AMP - CQG or the Sierra Chart Order Routing Service? Also, your Sierra Chart account which you have logged into this Support Board with is expired. If you have another, active Sierra Chart account you are using, then go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done. For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2021-01-23 22:48:11]     |
                Yes, im using CQG, AMP Send Me an Email with my Live Platform Login Credentials with the Account Name, but i didn't recived the Email with my Password...Where can i ask for it?
                 Date Time Of Last Edit: 2021-01-23 22:48:43
Private File  |
|   [2021-01-25 16:15:56]     |
                The first thing to try and do is change your Sierra Chart password. You can do this from the following page: https://www.sierrachart.com/PasswordReset.php If you do not receive the email to reset your password, then we need to know the Sierra Chart Account Name that AMP sent to you. If you do not want to put it into this forum, then start an Account Support Ticket, which is private. You can access the Account Support Ticket at this link: https://www.sierrachart.com/UserControlPanel.php?page=SupportTickets We need to know your Account Name to check and make sure that the email address we have for that account is correct. If it is not, then that would be why you did not receive the emails. For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2021-01-26 15:44:17]     |
                my account name is Yxelmtrader, my Email is Yxelmtrader@gmail.com I have sent an account support ticket with the Account Name that AMP Gave to me, but they reposted the message that i sent them in the support board....I have to wait something or that means that they can't resolve the problem??  |
|   [2021-01-26 16:35:45]     |
                We have responded in the Account Support Ticket. We apologize for the confusion.
