Date/Time: Fri, 21 Feb 2025 18:20:53 +0000
need help setup starting package
View Count: 487
[2021-01-21 15:55:20]
User777621 - Posts: 1
Hi, i want to setup my sierra chart to be able to trade s&p500 futures on the platform, but im not sure how it work since its my first time... so i have a trading account with AMP, i think i made a request to associate it with my sierra account .
here is the setup i want
-Sierra Charts (with Denali Data Feed & Order Routing through AMP Futures Brokerage)
-Sierra Charts Advanced Package 5 platform
-CME Data Bundle
-Denali Data Feed
can you tell me if i did it well ? because i open sierra chart and the data seems delayed
[2021-01-21 16:27:42]
John - SC Support - Posts: 38111
Your setup all looks correct and good on our end.
Usually when this occurs it is because the option for File >> Data/Trade Service Settings >> Allow Support For Sierra Chat Data Feeds is not enabled. Check that setting and make sure it has the checkmark next to it. Refer to the information here:
Data/Trade Service Settings: Allow Support for Sierra Chart Data Feeds (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings)
If that is enabled and you are still only getting delayed data, then follow these instructions to get us your Message Log:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
