Date/Time: Thu, 20 Feb 2025 19:43:50 +0000
On Trial for 14 days but pay for Real Time Stock data?
View Count: 610
[2021-01-15 15:17:52]
anson163599 - Posts: 5
I signed up to test the Number Bars and Time and Sales features of your software. It seems to be running on historical but I can't see any time and sales... is this because it is historical?
1. I thought the data should be delayed by 15mins but would update like a Real-time chart? Why is it that no chart updates show until I force a delete and re-download?
2. Can I pay for a Real-time Stock feed - Nyse/Nasdaq on the trial so I can see how it all works Real-Time?
I'm a volume trader and these are important for me to be able to use your platform.
Thank you
Anson
[2021-01-15 15:34:52]
John - SC Support - Posts: 38084
1. The only data that is delayed but constantly updated is the data from the CME Group. The other data (including U.S. Stocks) is delayed an only updates at certain intervals. Refer to the information here:
Sierra Chart Historical Data Service
2. Yes, you can use the Sierra Chart Exchange Data Feed and activate the U.S. Equities exchange in order to get Real-Time data. It does not matter that you are on a trial. Refer to the Setup Instructions here:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
Just be aware that the Real-time Data Connection fee is pro-rated for the month, but the Exchange Fee is not.
Date Time Of Last Edit: 2021-01-18 12:19:05
[2021-01-15 15:55:48]
Hi John,
Thanks for your reply.
Would this then be $10.50 + $25.00 (excluding any pro-rating)?
[2021-01-15 17:48:24]
Yes, exactly.
