Date/Time: Tue, 04 Nov 2025 14:40:52 +0000
Is this a CQG feature?
View Count: 690
|   [2020-12-28 20:09:31]     |
| User459170 - Posts: 262 |
                I am using Sierrachart and CQG. This morning has been a mess, I am glad this is not a trading day for me. If I log off Sierrachart and reconnect, there is a gap between the data at the time of login and at the time of log off. So for e.g. if I log off/disconnect at 9 am and reconnect at 11, there is no data between 9 and 11. Is this a CQG issue that needs to be sorted out with CQG? ** problem solved. It seems to have fixed itself somehow. Date Time Of Last Edit: 2020-12-28 20:45:14
|   [2020-12-28 20:22:50]     |
                We are no longer as of December 28, 2020 providing the Sierra Chart provided historical data service for CQG or Interactive Brokers users. For more information, refer to this Support Board thread: Jan 1, 2021 Changes to Historical Data: Interactive Brokers, CQG Also refer to this post for steps that you need to do now (which includes updating Sierra Chart): Jan 1, 2021 Changes to Historical Data: Interactive Brokers, CQG | Post: 245144 The solution to this problem is to use the Denali Exchange Data Feed for CME and EUREX data. Step-by-step instructions are here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* The first calendar month of this data feed is free. Let us know if you need help with the set up and we will help you through all of the steps. In the case of CQG you will then need to contact your broker and cancel CME and EUREX exchange fees through your CQG account so you do not pay exchange fees twice. You definitively do not have to pay any market data exchange fees through your brokerage account to CQG. This is not required. For other exchanges (ICE, HKFE) you need to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed As an alternative to CQG, we recommend using the Sierra Chart Order Routing Service: Sierra Chart / Trading Technologies Futures Order Routing Service In regards to using CQG provided historical data, we definitely do not recommend using that. It has an additional cost of 25 USD per month. The data delivery is slow and inefficient and causes Sierra Chart to freeze during the processing of it. Only 5 days of tick data is supported from CQG. And only current futures contracts are provided. Whereas with Sierra Chart provided data feeds, you will have access to 10+ years of reliable high-speed delivered tick by tick data. Once again we do not advise using CQG historical data and it will not work well with Sierra Chart. And we also provide no technical help or support for any CQG provided historical data or real-time data. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-28 20:23:11
|   [2020-12-28 20:28:08]     |
                I am going to test how things go with CQG for a few days and then decide which way to go. I have no other choice, but to use CQG for routing. In that case, do you see any major issues if I switch to Denali data and use CQG routing?
|   [2020-12-28 22:12:22]     |
                 do you see any major issues if I switch to Denali data and use CQG routing?  No not at all.
                Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
