Date/Time: Wed, 23 Sep 2026 11:30:20 +0000
Chart Replay
View Count: 1308
| [2020-12-17 16:55:22] |
| Shaquelle Oatmeal - Posts: 5 |
Hi Sir/Madam, I am trying to do a chart replay for ES from Jan 2020 - Dec 2020 for the Day VWAP chart as well as Market profile blocks and all of the HTF VWAPS. Every time i do it, the Day and HTF VWAP go to the correct date and will replay correctly but the Market profile blocks is just completely empty and doesnt seem to update. Have you any advise please? |
| [2020-12-17 17:57:02] |
| John - SC Support - Posts: 47980 |
First, it sounds like you are trying to replay on historical charts. Replays do not work on historical data, only on Intraday data. Refer to the information here: Replaying Charts: Introduction If you are trying to do this with Intraday data, then there should not be an issue. Although given how a TPO Chart doesn't really have a way to define a start time, you really should use the Use Start Date-Time option on the Replay Control window. Refer to the information here: https://www.sierrachart.com/index.php?page=doc/ReplayChart.html#UseStartDateTime For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-12-17 18:15:53] |
We are not understanding this clearly. Try increasing the replay speed. Here is the full documentation: Replaying Charts: Basic Chart Replay Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
